I want to use fromt and rear diffs auto tranny transfer case out of the xj and put it in my mj will this be easy or hard???
You will need to have the rear drive shaft from the XJ lengthened, or the DS from you MJ shortened.  Most everything else should be a direct swap.
There are lots of write ups on converting 2wd to 4wd.  Just search on here for it.
Thanks. The Mj was converted to 4x4 by PO from what i can tell it is 92 cherokee transfer case and front diff. Also has 4.5 rusty lift. The only reason for the change to have matching running gear
