anyone ever used the novak sk2x tc shifter kit in there mj ? i'm about to start the 2wd to 4wd conversion on my 87 in march . i have almost every thing i need except the tc shifter system , or would i just be better off going to the jy and pull a system from another cherokee ?
well i ended up pulling a stock tc shifter from a cherokee , i think i'm just going to use it and remove the z linkage system, and use the cable system to connect the tc to the shifter . think it should be ok .
Get the boost works kit. 41$ and it's perfect. I've newer tried the Novak kit but I have no complaints with the boost works kit plus it's way less $$$
I have the Novak cable setup on mine, no complaints at all. Easy to install and adjust, has worked fine for 3 or 4 years now.
thanks i'm looking into the novak cable since i don't have any of the brackets , only picked the stock shifter from a 96 cherokee the brackets and the z linkage was already gone , and i like the fact that the novak system comes with the brackets .
You don't need the brackets for the boost works kit
so the boostwerks is a direct link from the shifter to the tc , thats cool i could tell from looking at the pics on boostwerks site going to have to look at them again. the savings would help i case i need some other small part i may have forgotten  :thumbsup:
I have a cable shifter on my MJ and I bought because I didn't have the brackets. It's awesome. Mine was a PITA to install but after I got it adjusted correctly, it shifts like butter.
Other then the actual shift lever, you don't need any sort of brackets for the boostwerks kit
