Everything posted by chris71
yeah it would fun to fix the ecu . haven't had the time yet to trace it down , i have a another one in the truck already , and the one i pulled out on the work bench , with both a chilton's and hays manual . i'll spend some time this week and trace it down . should be able to get some high quality capacitors for it online of course.
well i found the problem , it's the pickup coil in the distributor (stator) whatever you want to call it , it's getting hot and starts dieseling , i found after i shut it down i can take a couple ice cubes down inside the distributor for a minute or two but it back together she start right up and run fine for a few miles , so in the morning i'm ordering a new pickup coil to replace it with . so this adventure i have found out that i have 3 bad cps sensors , found some bad spots in the green/white wire going to the icm the white plug . and a bad pickup coil in the distributor ( not looking forward to replacing that lol ) . i think it might be as old as the truck if it is 31 years ain't to bad for a pickup coil . i have also learned you can't rely on an analog multimeter when probing the pickup coil wires looking for the needle to swing . if it's running the needle will swing and the volts will even read right till it gets hot . oh almost forgot the ecu i took out and replaced i took it apart and pulled the board out , it did have a cap at location c-12 that was deformed a rather large bulge on it's cylinder , the ecu number is ef8953005428 other than that the circuits and board still look like new , looks like i have research to do to find out what the capacitor at c-12 is for ,
well i got another mopar cps sensor ,drilled the holes out and checked out put volts almost to .5 which is good from what i've read . checked out some more of the engine harness found a bad spot a factory crimp i missed awhile back that i didn't know about , the white plug to the icm has a green wire with a whit stripe on it the same wire had a break in it that was covered with tape anyways i fixed both places soldered and heat shrink , the idle smoothed out after , went for a drive for a few miles she acted up again but the symptom was different instead of dieing after coming back to idle at a stop it dieseled instead , no throttle responce turned the key off and tried to start again back to crank no start , unplugged the cps to check output volts still getting the same reading .493 at the cps plug ok thats good right , checked the tps it still checks good .8 and will rise and fall with the moving of the tps arm . probed the wiring harness for the cps all the back to the fire wall show a good reading . anyways after she sat for a few minutes started right back up running fine again like nothing happened . got home to check the stator with an analog volt meter to see if i was getting any needle swing while cranking and running seems to be ok , i don't have the tools to check the icm or the stator correctly . and i'm thinking the same as 88whitemanche that the icm is on it way out . and yes i checked for vacuum leaks at the intake mounting , the injectors , throttle body , vac lines , etc anywhere i could spray starting fluid to get a change in idle . so far no vac leaks found at this time .
the wires look ok and not melted i did have that issue about 6 or 7 years ago melted the plug was happy to find that msd had the echlin plugs with pins so it was an easy fix .since then i've rerouted the wiring so its not near the exhaust , probed them to check for continuity as far back into the wiring harness as i could get . well she died again last night checked output voltage on the cps while a buddy cranked her over didn't show any output , tried the other two cps sensors and got a .02 out of them , so i ordered another mopar cps from morris 4x4 last night . the bwd cps puts out no volts , the two mopar ones are only putting out .02 , so i'll have to apologize because i had hard time believing that all 3 were dead , but it is the only thing that makes since . but on a good note i've gotten really good at pulling the cps out lol, i have found that using a 1/4" drive 11mm shallow socket on a swivel with a small bicycle speed sensor magnet inside the socket works well , it keeps the bolts from falling into the bellhousing and makes it easier to start the bolts when reinstalling . of course break them loose with a 3/8 drive first, and finish tightening with 3/8 drive .
i don't know if it's getting heat soaked , i have checked the exhaust and intake bolts to make sure they were tight , no exhaust leak in the area of the cps that i can find . fuel ballast would be a good idea but the 87 didn't come with one . it has a relay on the passenger side that was getting hot , i replaced it last night along with the fuel filter , the fuel pump i replaced a month ago, cause the old one quit on me out on the highway , after getting the new one in thats when this drives fine for a couple days no problems , then all of sudden just dies , let her sit for 5-10 minutes starts right back up , cps was my first thought so it was replaced with one a new i already had , few days later died again wouldn't start back up . walked to the parts store napa bought another cps and a coil , walked home got some tools and back to the truck , replaced both the coil and the cps again , kept the ones i pulled out , drove good for another week and started doing the same thing now it's every few days it'll die , anyways i put another ecu in today , new plugs plug wires , fuel filter and fuel relay last night , checked fuel pressure again just to make sure i was 39psi, sprayed some wd40 around all the vacuum areas i could get to no change in idle . i still think the map sensor is faulty or going bad , if i remember right the map sensor is part of the system to tell the ecu how much fuel is needed ( correct me if wrong ) also the only way i've been able to get it to die in my driveway the same way it does while driving is to pull the fuel pump relay out while it's running , bad parts do happen i've had my fair share over the years . i really need to go drive around and see if it happens again .
yeah all of that has been done , i have good fuel pressure , i keep two of everything cps , coil, tps, iac , coil/plug wire , discap rotor, all of which have been replaced tested even tested right after it dies all show to be good. my thoughts are leaning towards either ecu,map sensor or o2 sensor , replaced fuel filter and fuel pump relay last night , haven't had a chance to test drive yet . but i'm sure it's going to run fine for another day or two before shutting down again . icm could be causing a problem , the weird thing is it only takes less than 5 minutes to start right back up and run great for a couple days , took the ecu out this morning don't smell burned and i haven't seen any shorts on the circuit board or anything melted. i'm going to try one of the other ecu's and see if the problem persists , found some info on the map sensor last night on how to test it with a ohm meter and handheld vacuum pump to check voltage output . looks like i'll just have to keep testing , till i find the problem .
so the two months i have been having an issue where my 87 will run fine and all of sudden die . after letting set for a couple minutes it'll run fine for a few more days and do the same thing again. anyways it an 87 comanche 4.0l ax15 np231 , i've been through the normal suspects , so far i have found a bad dis cap and rotor(replaced) checked cps and coil replaced both replaced fuel pump bosch replaced , each time it got better but still dies? checked fuel pressure it is good . it has an 89 ecu in it wondering if it could be the problem , even went through cruiser's tips again . haven't replaced the fuel filter yet , doing that tonight after work , any suggestions as to where else to look would be great , i have yet to check the iac and tps . those are also on my list of things to check tonight .
problems with climate control doors no longer working
chris71 replied to chris71's topic in MJ Tech: Modification and Repairs
that a great idea , gets it out of the right front inner fender area . -
so after checking all of the suggestions this weekend i found the vacuum leak . it was the line going into the firewall . somehow it got a hole rubbed in it fixed the hole and secured the line from rubbing on anything . thanks for the help -
thats a good idea i was under the dash installing the brake booster i might have unplugged some vacuum lines . -
How Do you delete the bed height vlave
chris71 replied to 88 pioneer Olympic's topic in MJ Tech: Modification and Repairs
http://comancheclub.com/topic/51268-load-height-sensing-valve-delete-bypass/ here's a write up on it in the diy section . -
i did disconnect some vacuum lines on the drivers side but only the ones that went to the factory air box that is no longer in the truck but that's been gone for over a year . and this just started after installing the 95 cherokee booster . i'll look at that vacuum line running up by the battery also . -
cruiser54 no i have not checked that vac line to the firewall , hornbrod the booster seems to be working ok but i didn't know about the testing , or even think to check the check valve on it . i'll check both suggestions after work today when i get home . i'll update what i find thanks -
so here the problem i've changed over to a dual diaphragm brake booster . and since the change over my climate control doors for defrost floor and vent don't work now . just blows through the defrost vents ? i still have the small round vacuum canister , so far i've checked it for leaks using a vac brake bleeder tool . it holds vac and i've replaced the vac line from it to the manifold , is there a way to fix this or do i just need to go to the jy and get the larger vac can ? or would an inline vac pump work like whats on the newer jeeps ? thanks in advance
before https://scontent-atl3-1.xx.fbcdn.net/v/t1.0-9/10527378_1514786028751096_8267215454171969803_n.jpg?oh=40fb32a963267d3f42e7b4118bd85f28&oe=5864479B after https://scontent-atl3-1.xx.fbcdn.net/t31.0-8/14500524_1850134935216202_6578261475616861324_o.jpg still have a few things to do . but lift is done , found a camper shell . changing out to buckets and full console , monster line the whole truck blue with black trim, and at the moment sketching out some plans to build a sleeping living area in the bed ,
so i done the ba 10 to ax 15 swap and i am trying to figure out what master & slave cylinder to use ? the ax 15 and 231 both came out of a 97 cherokee the external slave was all ready gone when i went to the jy , any how just wanting to know what would be the best fit as far as firewall mounting with the master , or if i can just adapt the external slave to work with the current master cylinder that was in the truck to begin with , i dug through almost all the swap threads but didn't see anything on master&slave cylinder changes (or at least i didn't see one ) . any thoughts would be great , thanks
c2c fab replacement floorboards
thank you hornbrod :thumbsup: -
good to know there a good fit , i didn't see them in two sections just left and right sides , i'll look again if not i can cut them . only really need the front half of each one . the back halfs look good with only small pin holes one or two spots . -
cool thats what i was thinking , just wasn't 100% sure thanks :thumbsup: -
hey all been a few months since i've been on here , have a couple questions . 1. does anyone have any experience with c2c fab's floorboards , if so were they a good fit ? 2. needing to remove the old airbox since i'm running a spectra cold air intake , i left the old air box due to the vac lines and have been unsure if i can just remove them and plug the vac ? anyhow i've been making good progress on the conversion from 2wd to 4wd , about to start the install of the 8.8 this weekend , and bushwacker fender flares , gotta do the floorboards soon there getting bad , also does anyone remember what that frame treatment is starts with a p black in color it's a undercoating ? hope those pics post if not i'll try again , this is where i'm at in the work being done dana 30 is in new suspension and lift , ax15 and np231 are in driveshafts are being shortened . getting close thanks in advance for any help with the above questions .
Another brake booster mc swap question?
ok
