RynoMJ Posted December 29, 2015 Posted December 29, 2015 I'm getting all my bearings straight to do an AW4 swap in my 88 replacing the BA10. I'm going with an electronic shifter since I cannot locate a harness that will work. The last thing I cannot seem to figure out/see is where the throttle valve cable from the AW4 will hook up to my throttle body. Will I need to locate a different body? Any body have a picture of how this connects to the throttle. Thanks.
gogmorgo Posted December 30, 2015 Posted December 30, 2015 Can't guarantee the Renix setup will be the same, but the HO one attaches to the same pivot as the throttle cable. There are three on there, the throttle cable, the cruise control, and the throttle valve. The cables are held by a bracket that bolts to the intake. I'll snap a pic tomorrow if I remember while there's daylight.
RynoMJ Posted December 30, 2015 Author Posted December 30, 2015 I'm thinking it must be different because I don't see any pivot points on the throttle cable lever. Anyone with a Renix know?
gogmorgo Posted December 30, 2015 Posted December 30, 2015 So this is what I'm talking about. From the front: The lower one is the tv cable. The other two attaching on opposite side of the same point are the throttle cable and cruise control. And from above, (the top of the picture is towards the front of the truck. Top is throttle valve, and the other two are the throttle cable and cruise control. It's set up to move opposite the throttle cable, by that I mean that as the throttle cable pulls the throttle open, the throttle cable retracts into the sheath, but it pulls the tv cable out of its sheath, and when the throttle is closed, the throttle cable extends but the tv cable retracts. Looks like the throttle "arm" could be different between manual and automatic, just not having that extra cable attachment point for the tv cable. Beyond the Renix/HO difference of course.
RynoMJ Posted December 30, 2015 Author Posted December 30, 2015 Thanks for the reply really appreciate it. It's looking like I need to find a renix automatic throttle body since mine doesn't have a spot for the cable to attach.
64 Cheyenne Posted December 31, 2015 Posted December 31, 2015 Since the TCU for a Renix is stand alone, couldn't a person make their own stand alone harness between the AW4controls, NSS, and the TCU?
gogmorgo Posted January 1, 2016 Posted January 1, 2016 With the proper know-how, it would be pretty easy to set it up for fairly cheap. If you're not into analogue electronics, an Arduino could do it, probably even for less than the cost of a new tcu (if such a thing still exists) But you'd somehow still have to reference throttle position somehow to get the proper kick-down behaviour... Might be able to tap into the tps. You could even work in your own shift map, set multiple maps depending on some kind of input (say power/comfort switch)... Of course there are also a few aftermarket controllers available. I've tossed this idea around a bit, but never had much of a reason to actually do it.
cruiser54 Posted January 2, 2016 Posted January 2, 2016 I'm thinking it must be different because I don't see any pivot points on the throttle cable lever. Anyone with a Renix know? There's a bracket on the auto throttle body that you need.
HOrnbrod Posted January 2, 2016 Posted January 2, 2016 There's a bracket on the auto throttle body that you need. ^^ 4 posts up. Read much?
cruiser54 Posted January 3, 2016 Posted January 3, 2016 There's a bracket on the auto throttle body that you need. ^^ 4 posts up. Read much? I read. Not much on photos though.......
HOrnbrod Posted January 3, 2016 Posted January 3, 2016 There's a bracket on the auto throttle body that you need. ^^ 4 posts up. Read much? I read. Not much on photos though....... Obviously.
cruiser54 Posted January 3, 2016 Posted January 3, 2016 Never imagined you even kept a photo of anything Renix..............
HOrnbrod Posted January 3, 2016 Posted January 3, 2016 Never imagined you even kept a photo of anything Renix.............. It's one of yours. I stole it from your hard drive.
