onlyinajeep726 Posted December 22, 2015 Share Posted December 22, 2015 Sorry if I'm beating a dead horse, but besides advancing the timing by 2 degrees, is there any major difference between the two? I know to get a MOPAR one and I plan to follow Cruiser's tip to enlarge one of the bolt holes.Is there any negative affect to using the HA CPS? Link to comment Share on other sites More sharing options...
daking Posted December 22, 2015 Share Posted December 22, 2015 do you have the part number for it? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted December 22, 2015 Share Posted December 22, 2015 Mopar #53005421 for the renix years . Link to comment Share on other sites More sharing options...
daking Posted December 22, 2015 Share Posted December 22, 2015 I'll pick one up. I have the transmission out right now. best time to install a CPS.. I can't find one on line. guess its a dealer item Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 22, 2015 Author Share Posted December 22, 2015 I have a part number for both, but that doesn't answer my question lol. :P The regular Mopar CPS is P/N: 33004761 High Altitude Mopar CPS is P/N: 53005421 Link to comment Share on other sites More sharing options...
mik666 Posted December 22, 2015 Share Posted December 22, 2015 i actually compared the two in a non- quantitative way just last week- both were new. Since i have a 4.0 2wd auto it takes minutes to swap them out and after drilling out the mounting holes as recommended in the renix tips swapped the two and compared the general idle quality and acceleration about the hood sort of method - I found the HA to give a slightly better idle , acceleration was hard to say but certainly was no worse with the HA CPS so i went with it - i would of liked to compare them on some hills to see if there was a discernible difference, but i'm happy i went with the HA one Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 22, 2015 Share Posted December 22, 2015 I have the transmission out right now. best time to install a CPS.. Maybe so, but I recommend waiting to install the CPS until after the tranny is bolted up, prevents the CPS from being damaged while you wrestle the tranny into place. Guess how I know... Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 22, 2015 Share Posted December 22, 2015 :popcorn: Link to comment Share on other sites More sharing options...
Eagle Posted December 22, 2015 Share Posted December 22, 2015 I've been running one in my '88 Cherokee for fifteen years. I'm basically at sea level -- you will NOT see any difference in performance, but if you drive gently you will see an improvement in gas mileage. All the high altitude CPS does is allow the timing to advance a bit farther. But when you drive peddle to the metal, the engine is always at the point of detonation and the knock sensor is controlling how far the timing can advance -- so under heavy load or heavy acceleration, the knock sensor overrides the CPS and doesn't allow that extra 2 degrees of ignition advance to kick in. Where it does become operative is at cruise throttle. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 23, 2015 Author Share Posted December 23, 2015 Thanks for the kind responses, especially yours Eagle. That's what I was looking for. Link to comment Share on other sites More sharing options...
