groffman056 Posted December 15, 2015 Posted December 15, 2015 will 1987-90 jeep cherokee doors fit on my 1988 jeep comanche pioneer
gogmorgo Posted December 15, 2015 Posted December 15, 2015 The front doors on a four-door XJ. I'm pretty sure 84-96(? Maybe 95) will work without modification.
Black89Comanche Posted December 17, 2015 Posted December 17, 2015 the front half of the Cherokee is the same as the Comanche within you year range at the very least.
4.0forlife Posted December 17, 2015 Posted December 17, 2015 Be careful after a certain year they switched the way the locks are and they no longer will interchange with the ones on your comanche
Zebvance Posted December 17, 2015 Posted December 17, 2015 the front half of the Cherokee is the same as the Comanche within you year range at the very least. Not true. Still many things different that are not noticeable to the naked eye. One major is the roof line. but yes the doors will still work,
Blue88Comanche Posted December 17, 2015 Posted December 17, 2015 the front half of the Cherokee is the same as the Comanche within you year range at the very least. Not true. Still many things different that are not noticeable to the naked eye. One major is the roof line. but yes the doors will still work, True, but how many people are going to swap a roof? that requires, cutting, grinding, and welding. the Seats or parking break the other hand are items that can be removed easily but mods are required for use between the two platforms. Hunting for parts, 4 door Cherokees are a safe bet from the dash forward.
Zebvance Posted December 17, 2015 Posted December 17, 2015 the front half of the Cherokee is the same as the Comanche within you year range at the very least. Not true. Still many things different that are not noticeable to the naked eye. One major is the roof line. but yes the doors will still work, True, but how many people are going to swap a roof? that requires, cutting, grinding, and welding. the Seats or parking break the other hand are items that can be removed easily but mods are required for use between the two platforms. Hunting for parts, 4 door Cherokees are a safe bet from the dash forward. Its came up plenty before when people find the LUND visors off of cherokees and want to put them on comanches.
Blue88Comanche Posted December 17, 2015 Posted December 17, 2015 the front half of the Cherokee is the same as the Comanche within you year range at the very least. Not true. Still many things different that are not noticeable to the naked eye. One major is the roof line. but yes the doors will still work, True, but how many people are going to swap a roof? that requires, cutting, grinding, and welding. the Seats or parking break the other hand are items that can be removed easily but mods are required for use between the two platforms. Hunting for parts, 4 door Cherokees are a safe bet from the dash forward. Its came up plenty before when people find the LUND visors off of cherokees and want to put them on comanches. I keep forgetting our trucks had those visors, :cheers:
