NY 1986 lwb 2.8 v6 part out 36k miles
WNY-J24
Just bought a 1986 lwb 2.8 v6 2wd comanche with front end damage. Seems like it was a barn find 36k miles and the front was smeared in traffic. Haven't tried it myself but seller says the engine runs and auto tranny works.
Listing parts with prices obo
Rochester ny
(Some items already possibly taken/on hold by local mj friends. Lwb bed, doors interior colored plastics, bench bracket, tailgate, taillights)
Update: adding parts
Lwb gas tank skid plate $?
I added photos it doesn't look exactly like the diagrams online but it is a plate and not just straps
Steel bumper $80
(Says 8000 lb tow weight) some surface rust but looks solid
Tan leather (pleather?) Bench great condition no rips or spots $130
Rear non slider glass $20
Rear glass gasket $45
Cab side vent trim $30
Wheel hub covers $40 for 4
Wheel steel trim $25 for 4
Lwb gas tank with fuel sender $75
(Anyone know if this 86 lwb 2.8 version is compatible with later years?)
Really nice vinyl floor $?
let me know if you want to know about any parts I didn't mention. All interior non colored parts are available (heater unit radio, dash....)
Still have to check and see what rear axle type it is, if there are any skid plates
  • 4 weeks later...
Plugs for the light bulbs may be the same. The other end of the harness might be different as stroker says.
Do you need a whole harness or just the end?
Should be taking the bed off in the next week or two, I can let you know then. I want to get the tank out and skid plate if someone wants them. This is the best I can see so far
It should fit a long bed of any year (experts can chime in) but the fuel pump and sender is likely different for any year after 86 since the 2.8 v6 changed to the 4.0 I6
Damn, i was hoping it would be similar enough to the 88. i need the whole harness the last owner hacked and spliced up the harness pretty badly, but thanks for the heads up stroker
Archived
