coheed Posted December 1, 2015 Share Posted December 1, 2015 1986, Comanche XLS. 2.8 / 904 / NP228 / D30 / D35 / LWBBuild date: Unsure, sticker is illegible Location: Maiden, NC Status: Awaiting "Restoration" Notes: Charcoal Metallic, Tan interior, Buckets w/ full console, had all factory chrome trim but some will be going away. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 21, 2019 Share Posted May 21, 2019 Build date: 9/10/85 Link to comment Share on other sites More sharing options...
JMO413 Posted June 28, 2020 Share Posted June 28, 2020 JP62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AGY AJZ BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGY Transmission - 3-Spd. Automatic, EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Link to comment Share on other sites More sharing options...
coheed Posted February 12 Author Share Posted February 12 On 6/27/2020 at 11:45 PM, JMO413 said: JP62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AGY Leather Flexible Seating Group AJZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGY Transmission - 3-Spd. Automatic, EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN On 5/20/2019 at 10:59 PM, eaglescout526 said: Build date: 9/10/85 Do either of you guys happen to know which codes got reused over the years? I'm curious as to how this truck (my grandfather's) was originally optioned from the factory. Like would the RAF code mean that the RX135 that was in the truck was ordered with the truck, or the code got reused and it was a different option at the time? Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 12 Share Posted February 12 I don’t think radio is one that was reused. I know Pete deleted some that were reused which is why some of those codes are blank. As far as what radio was stock is a great question since there was so many. But given it says AM/FM/MTR could be a fancy unit. I THINK MTR stands for Magnetic Tape Reader which could be cassette. Unless there’s a code out there that says cassette. Link to comment Share on other sites More sharing options...
Pete M Posted February 12 Share Posted February 12 apparently I missed a couple? you don't have leather seats and you don't have a 750amp battery. when the code explanation is wrong, it's usually very wrong. usually it applies to a much newer chrysler product. Link to comment Share on other sites More sharing options...
coheed Posted February 13 Author Share Posted February 13 Ok, so everything that seems like it may fit given what parts were on the truck has a decent chance of being the original option? Could the seat code have corresponded to the higher end seats? Because it did have the highland check with vinyl winged bucket seats. Link to comment Share on other sites More sharing options...
