Jackrabbit41 Posted November 20, 2015 Share Posted November 20, 2015 So I'm doing my 8.8 swap and i decided that it was good to wait until the day before to figure this out (not). So after rolling this thing around 500 times the brake lines are kinda catywompus. They are in good shape but i just need to put it back. Also my main concern is do the 8.8 brake lines go right into the stock comanche lines? thanks here's some pics of what I have going on. [/url]">http:// [/url]">http:// [/url]">http:// I bought new extended brake lines, the ones off of alexia lift kit and so I have longer ones but will those work? thanks Edit/ Also does anyone know what threads are in the 8.8 yoke? I got the flange adapter but I need to get some grade 8 hardware for it. Link to comment Share on other sites More sharing options...
Lee21490 Posted November 20, 2015 Share Posted November 20, 2015 I don't remember how i got my brake lines to work for the 8.8, I remember it being really easy though. Bolt is M12X1.75X27.0 http://www.amazon.com/Ford-Driveshaft-Bolts-N800594S100-M12X1-75X27-0/dp/B00GK4XGW4/ref=pd_sim_263_1?ie=UTF8&dpID=31oGXAwNjRL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0APFZ9HGXETV6RNWXXRF here's a link to them on amazon. Link to comment Share on other sites More sharing options...
DansGreyMj Posted November 20, 2015 Share Posted November 20, 2015 When I did my 8.8 I used two passenger side caliper soft lines from an explorer and used off the shelf parts store hardlines and connected them to an extended xj rear stainless brakeline. Link to comment Share on other sites More sharing options...
88whitemanche Posted November 20, 2015 Share Posted November 20, 2015 They will fit to the ford lines... You can actually set your hard lines set up like the Comanche and go from there.... Here's a thread I started with a few pics of an 8.8 with the jeep brake line set up... http://comancheclub.com/topic/48207-88-lsd-or-not-lsd/page-2?do=findComment&comment=491572 Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted November 20, 2015 Author Share Posted November 20, 2015 I don't remember how i got my brake lines to work for the 8.8, I remember it being really easy though. Bolt is M12X1.75X27.0 http://www.amazon.com/Ford-Driveshaft-Bolts-N800594S100-M12X1-75X27-0/dp/B00GK4XGW4/ref=pd_sim_263_1?ie=UTF8&dpID=31oGXAwNjRL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0APFZ9HGXETV6RNWXXRF here's a link to them on amazon. Thanks. After k get those I'm starting the swap tonight! Really excited to finally do this Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 21, 2015 Share Posted November 21, 2015 When I did my 8.8 I used two passenger side caliper soft lines from an explorer and used off the shelf parts store hardlines and connected them to an extended xj rear stainless brakeline. ^^ THIS. That's exactly what I did, see below: Link to comment Share on other sites More sharing options...
