Newton Posted November 14, 2015 Share Posted November 14, 2015 Hi when i start comanche and put in drive its very sluggish have to rev it hard so it could move feels like its starting in second gear if i put it in 1st it works like in should but if put in drive after i start moves really slow any idea what could be the cause does this mean my transmission is bad? Link to comment Share on other sites More sharing options...
gogmorgo Posted November 15, 2015 Share Posted November 15, 2015 Sounds like what happens when the transmission controller is unplugged. What happens is the transmission goes into a kind of manual mode, where the gear lever corresponds directly to the gear you're in. D puts you in overdrive, 3 in third, and 2-1 puts you in first. Check the trans fuse, and wiring to the tcu, which is bolted to the back of the lower dash panel, about where the passenger's left knee would be. I suppose it could also be a bad tcu, but I think that's pretty rare. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 15, 2015 Share Posted November 15, 2015 ^ This. If not that, a bad solenoid in the trans. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 15, 2015 Share Posted November 15, 2015 The 7.5 A TRANS fuse under the dash...or the 10 A in-line fuse under the passenger dash in the location described above. All easy fixes, even if it's a solenoid. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 15, 2015 Share Posted November 15, 2015 Check this fuse first: Link to comment Share on other sites More sharing options...
Newton Posted November 16, 2015 Author Share Posted November 16, 2015 Thanks for the reply guys ..appreciate it Link to comment Share on other sites More sharing options...
cruiser54 Posted November 16, 2015 Share Posted November 16, 2015 Pull the under dash fuse near the TCU first. Link to comment Share on other sites More sharing options...
