Keith Posted November 14, 2015 Share Posted November 14, 2015 1989 4.0 5 speed, out of the blue it has started running very rough at idle, runs great as the RPM's increase but my mileage has crashed from 18-22 Hwy to about 13 and less than that in city. Any suggestions? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 14, 2015 Share Posted November 14, 2015 Check the hose from the throttle body to the map sensor. Also, when was the last time the O2 sensor was replaced? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 14, 2015 Share Posted November 14, 2015 http://comancheclub.com/topic/48778-loss-of-gas-mileage/?p=496535 Link to comment Share on other sites More sharing options...
Keith Posted November 15, 2015 Author Share Posted November 15, 2015 Have had Commanche for 15 years and never changed O2 sensor, will try that. Thank you Link to comment Share on other sites More sharing options...
Pete M Posted November 15, 2015 Share Posted November 15, 2015 have you run through these yet? http://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ Link to comment Share on other sites More sharing options...
Crash Posted November 15, 2015 Share Posted November 15, 2015 Test/swap out IAC. Also, in my experience, whenever my mileage takes a dump, the O2 sensor is usually the cause. Also, test/replace as necessary, MAP sensor. Link to comment Share on other sites More sharing options...
Keith Posted December 2, 2015 Author Share Posted December 2, 2015 Changed the O2 sensor and the MAP sensor, neither helped. Filled up today 11 mpg as compared to 17 -20 in the past. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 3, 2015 Share Posted December 3, 2015 See Post 5...... Link to comment Share on other sites More sharing options...
metrictonner Posted December 4, 2015 Share Posted December 4, 2015 If an ordinary tune-up fails a rough idle generally indicates bad fuel injectors not bad O2 sensor. Bad mileage indicates a failing O2 or MAT. Sometimes the MAT can be tricked out by sludge build-up in the intake manifold (from the EGR and CCV crankcase breather) outgasing and causing the MAT to run cool but this would only cause bad mileage not rough idle. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 4, 2015 Share Posted December 4, 2015 If an ordinary tune-up fails a rough idle generally indicates bad fuel injectors not bad O2 sensor. Bad mileage indicates a failing O2 or MAT. Sometimes the MAT can be tricked out by sludge build-up in the intake manifold (from the EGR and CCV crankcase breather) outgasing and causing the MAT to run cool but this would only cause bad mileage not rough idle. I disagree that a bad O2 sensor does not cause a wonky idle. Quite common actually. For the Renix years, 87-90, the O2 sensor has 3 wires, 2 black and 1 orange. The orange wire (largest gauge of the 3) is the 12-14 volt power that comes from the O2 sensor heater relay on the passenger side firewall, and that powers the internal heater in the sensor so that the sensor can work at idle, and almost immediately after start up. Loss of that power will hurt gas mileage even with a good O2 sensor. One of the black wires is a common ground for the heater power and O2 signal to the ECU, so a poor ground will give a voltage feedback from the heater power input, to the ECU causing poor mileage even with a good O2 sensor. The third wire, also black is a voltage feed wire, 5 volts, from the ECU to the O2 sensor. The O2 sensor is an O2 concentration sensitive variable resistor. At optimal O2 concentration the 5 volt input feed to the O2 sensor drops to 2.45 volts due to losses across the O2 sensor to ground. That same wire if disconnected from the O2 sensor will read 5 volts constant to ground. At idle that voltage should read 1-4 volts oscillating quickly back and forth roughly once every second. At 2000 rpm it should run between 2 and 3 volts max, and is optimally running between 2.3 and 2.6 volts at 2000 rpm (in park). A digital meter can NOT be used for reading the O2 sensor voltage, but it can be used to test the ground and the 12-14 volts to the heater and the 5 volt feed from the ECU with power on and engine off. You must use an old style analog meter with the needle gauge on the display to see the voltage swing back and forth with the engine runing. If the O2 sensor readings are not right, say they read 4 volts or 1 volt steady, you have a problem. BUT before you blame the O2 sensor make sure it has good wiring, and make sure the proper voltage is feeding it, by turning power on, engine off to read the engine off voltage feeds (12-14 volts on the orange wire, and 5 volts on one of the two black wires), and ensure the ground wire (power off) reads less than 1 ohm to the battery negative post. A leaky exhaust system or leaky fuel injector(s), or bad compression, bad rings or leaky valves, bad plugs, wires, cap, rotor, HV coil, and so on, or combination of these, can also cause a lean or rich condition that gives you high or low O2 sensor readings that are not the O2 sensors fault, so try and verify those other items also before buying parts like an O2 sensor to fix your problem. Link to comment Share on other sites More sharing options...
