Engine vibration
So on my 90 mj with 4.0 aw4 I am having vibration problems that I am pretty sure are coming from the engine. It makes the vibration in neutral park drive reverse etc. so I doubt it's the driveline. I have replaced the motor mounts and trans mount. After changing those it's somewhat better but now it is pronounced between 1750-2500rpm then it goes away below and above that range. What can I start looking at? Need to figure this out its my daily driver
Ok so I changed my fuel injectors last night for an extra set I had thinking maybe this would have an effect on the truck. Made no difference. I checked my fuel pressure and it is low, would that cause this issue?
  • 4 weeks later...
Ok so finally I tracked this issue down to the upper aw4 to 4.0 bolts being loose. I tightened them up this afternoon and took it for a test drive. Everything seemed right again the vibration was completely gone. After a few more blocks the vibration started to come back. When I got home the bolts were loose again and backed out a few threads. What can I do to stop this?
Lock washers under the bolts?
Make sure the other two bolts are tight as well. Also the torque converter to flexplate bolts.
I had those bolts come loose, only I didn't catch it until it was too late. All but one had either come out completely or sheared off. The resulting engine-trans misalignment wrecked the flexplate and I'm pretty confident it also contributed to the main and thrust bearing problems that lead to me replacing the whole motor.
You might also want to check your motor and trans mounts. Mine were bad, although that might be unrelated on a 300,000 mile truck.
Took the truck for a test drive again after letting the locktight set for over 12hrs. Bolts loosened up again. Seriously what can I do? I'm not sure that a lock washer will work being the bolts are backing out of the block. Any ideas? Please help I need to fix this before work tomorrow
If locktight didn't help, you're right, probably a lock washer won't either. If they're the original bolts, see if you can replace them with new. If they're not original, make sure they're the right bolts, and not too long and bottoming out in the block.
If they are just backing themselves out, there's a vibration causing it. This may be one of the lesser symptoms of whatever is causing that, so it nay be pretty important to solve it beyond just putting the bolts back in. Again, are you motor mounts in good shape and the two larger bellhousing bolts still tight?
That's the stock size, so far as I can tell. The mechanic who put mine back in used 2" long bolts, with a flat washer and a lock washer. I'm not 100% certain on the thread size, although they look like 3/8-16. There's a reasonable chance they were helicoiled, though, so I can't guarantee they weren't drilled deeper. But they held tight for ten months and 4,000 miles until I swapped my flexplate, and then a couple months and maybe another 1000 miles or so until I changed out my motor.
How tight are you torquing them? One of mine was actually a bit distorted, looked like it got stretched a little. I'm pretty sure I put them back in to about spec.
It's hard for me to tell you how tight I am actually torqueing them down, i can't fit my torque wrench in the spot underneath where I am working. It's pretty tight though. I retorqued them this am now and we will see what happens today on my way to work, guess I'll try washers and lock washers tonight if it doesn't hold today.
I used a few feet of extensions to get to mine when they were in the truck, but I also had the whole trans out, so likely the engine was tilted back for better access. I've also seen people recommend pulling the shifter and going through that hole, but I couldn't get that to work for me, my selection of extensions at the time either put me too long or too short.
I have been dropping the crossmember and lowering the engine/trans combo to get at the bolts using my longer extensions. Works pretty well. I can also get to the passenger side bolt with a wrench from the engine compartment. I used a new bottle of loctite Sunday and haven't had to try the lock washers yet as this seems to be working fine so far. Since Sunday night I've put on over 100miles and no problems yet, truck is a pleasure to drive again.
So I spoke to soon, this issue came back. Now I am fine as long as I only drive on city streets, but if I get on the highway the bolts loosen themselves again. I have tried loctite, lock washers, new bolts, and all three at once too. I can't get these bolts to stay in place. I'm guessing I have a vibration problem somewhere else that is causing these things to come loose. I can't find any other loose bolts. What can I look for? I really want to get this fixed before winter so my girlfriend can drive it on bad snow days. Any ideas?
^^^  You ever use these Adam? The three bolts on my exhaust header collector flange are constantly loosening up and taking out the gasket. Like Dando I've tried everything, and was going to try the Stage 8 bolts next. I'd need a set of 3/8" three fasteners, and as far as I've seen, they don't make a 3-bolt kit.
Thanks Bo. But I'm not sure I understand how they work. My header collector to the exhaust flange uses three 3/8" x 1" bolts and nuts. I can see how they would keep the bolt from turning and loosening up out because of the clips on the bolt head, but what about the nut end of the bolt? What keeps the nuts from vibrating loose?  :hmm:
