What would you do?: D44 vs 8.25
A client has given to me, through bartering, a 93 XJ, 4.0, 4x4, auto w/ a CAD D30 and an 8.25.  Since it is an auto, I assume it is 3.55.
My MJ has a factory D44 with 3.07.
I am going to do a straight swap up front: my CAD D30 (3.07) for the XJ D30 (3.55).
My original plan was to re-gear the D44 to 3.55.  I thought the XJ has a D35, but upon looking closer, it is an 8.25. (Oval shape, flat spot on the top and bottom.)
Now, I am considering a swap of the D44 for the 8.25.
This is what I am confronting:
To re-gear:
I don't have to remove either axle.
I have to get the R&P and have someone install it.
I don't have to mess with the brakes.
I keep the factory original components.
To swap:
I have to remove two axles.  One axle has to be installed.
I have to get the perches and shock mounts relocated.
I have to mess with the brakes (Can you say disk conversion?)
What to do with the extra axle?
My MJ is my DD.  I don't any wheeling with it.  The most offroad this sees is a dirt road to some property in WV.
For my driving habits, why is one axle better than the other?
Your thoughts, please.
Seconded and thirded. Keep the D44, re-gear to 3.55, then slide convert to rear disks later at your convenience if needed.
This I would think is an important consideration for your rig.  :thumbsup:
Thanks to everyone.
I was leaning toward keeping the D44, but wasn't sure if an 8.25 was worth changing to.
Who makes the best R&P and install kits?
Since you will be going from a 3.07 to 3.55 on your D44, no worries about the carrier since the break is 3.73. I went from 3.55 to 4.10 when I re-geared my D44 and used "thick" gears which enabled me to keep my existing limited slip carrier. In your case it's a simple R&P re-gear. I like the original Dana gear sets the best, but they didn't make the "thick" gears I needed. So I went with Yukon gears. I've used Yukon gear sets in the past too with good results. A bit more than the offshore Chinese gears, but worth the extra $$ I think. But who knows - maybe they are all manufactured offshore now..........
