88mj2.5 Posted October 7, 2015 Share Posted October 7, 2015 I have a 96 motor full harness and everything but the hvac stuff I also have a complete 95 xj that I was going to use the motor out of. Both are or were 5 speeds. I was wanting to know if I could use the 96 harness with the 95 motor and the 95 hvac with the 96 harness? Then what all would I need to make an aw4 work with the 5 speed harness? It's going in my 88 2.5 ax5 Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted October 16, 2015 Share Posted October 16, 2015 I just did a 4.0 swap in my 1986 and I used a 1994 grand cherokee engine with a 1996 XJ harness, everything plugged right in even HVAC, I would think a 1995 Cherokee engine would work if a ZJ engine did Link to comment Share on other sites More sharing options...
88mj2.5 Posted October 17, 2015 Author Share Posted October 17, 2015 thanks man starting on this on Monday. I have all week off I'm hopping to have it about done by then at least the harness and motor in Link to comment Share on other sites More sharing options...
sbczr2 Posted March 27, 2016 Share Posted March 27, 2016 I'm getting ready for my swap harness and all any heads up on what I'm about to get in to Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 27, 2016 Share Posted March 27, 2016 I just did a 4.0 swap in my 1986 and I used a 1994 grand cherokee engine with a 1996 XJ harness, everything plugged right in even HVAC, I would think a 1995 Cherokee engine would work if a ZJ engine did So you used an OBD2 96 harness and PCM with a OBD1 94 engine? Did you swap in new OBD2 sensors? Link to comment Share on other sites More sharing options...
Eagle Posted March 27, 2016 Share Posted March 27, 2016 I don't know when the ZJ went to OBD2. The XJ was OBD1 through 1995. 1996 was a sort of transition year -- the '96 XJ was OBD2 because the law required it, but it was still the old body style so the OBD2 implementation was sort of a kludge. 1997 was when the entire chsassis harness was revised for a proper OBD2 implementation. So I share Hornbrod's question -- how did you make the OBD2 harness play nice with the OBD1 engine? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted April 30, 2016 Share Posted April 30, 2016 Following... Also, started this thread. Useful information here over time, hopefully: http://comancheclub.com/topic/50289-renix-to-ho-harness-and-engine-swap/ Link to comment Share on other sites More sharing options...
