Jackrabbit41 Posted September 11, 2015 Posted September 11, 2015 Just wondering what to get for a 6 inch lift for bump stops? Thanks
Crash Posted September 12, 2015 Posted September 12, 2015 I like the prothane coil inserts. I would probably go with the 8-ring ones. They are a progressive bump so they compress a bit. Definitely better to start a little tall with those, and you can cut off a ring if necessary. For the rear, prothane and other companies make extended bump stops. I would probably use one of those, maybe along with a 2x4 (or whatever) square tube "adapter" in between the frame mount and the bumpstop. Or, if you are SOA, either use spring plates with a built-in bump stop mount or add to your existing plates to "extended" them.
Pete M Posted September 13, 2015 Posted September 13, 2015 length of bumpstop is controlled more by the tire size than the lift. e.g: a 6" lift with 27" tires won't need any bumpstop alterations. what size tires are you running?
neohic Posted September 13, 2015 Posted September 13, 2015 length of bumpstop is controlled more by the tire size than the lift. e.g: a 6" lift with 27" tires won't need any bumpstop alterations. what size tires are you running? Don't for get that you don't want a leaf spring in invert on itself either regardless of how much you can stuff a tire into a fenderwell.
Pete M Posted September 13, 2015 Posted September 13, 2015 good point. I was thinking of fronts. and now that I think about it, shocks are sometimes another determining factor (my own truck for instance). It's been a long day and the brain is tired. basically it's your personal setup that determines proper bumpstop length. Gotta put it through its paces and see what hits first. :thumbsup:
Jackrabbit41 Posted September 14, 2015 Author Posted September 14, 2015 length of bumpstop is controlled more by the tire size than the lift. e.g: a 6" lift with 27" tires won't need any bumpstop alterations. what size tires are you running? I have 31s now but come next summer I'll try out 35s. Hopefully 4.10s are enough to handle 35s if not I'll get 33s
