Another AX-15 swap thread.
Picking up an AX-15 Friday for 150$. Internal slave, 130k miles on it. I plan to use my current T-case, of course. How hard is changing the input shaft? And where can I get an input shaft for cheap? Other than those parts... What do I need? I want to use my current crossmember and add a spacer to the crossmember to account for the bigger size of the AX-15, how much of a spacer do I need to add and how should I mount the crossmember? I know theres a second set of mounting holes further back that you use, but are they threaded? I just changed my slave and clutch... literally JUST changed them. Should I change the slave again for any reason? Will my current driveshafts still work? Just a good walkthrough would be appreciated. I would search... but I've been up 27 hours and only can sleep 5 hours before work haha. I appreciate any replies, thanks!!!
BleepinJeeep on Youtube has a video about changing the input shaft.  Plus, there are other videos about that.
The drop is about 3/4".  You will also need the mounting bracket.  I do believe the BA will fit the AX.
The holes are threaded.
The drive shafts will work with no problems.
I have an extra crossmember and mounting bracket I could sell.  I painted the CM with Por15 so it will never rust.
I heard the change of PB was in 92? I'm thinking I may just find a new Tcase to save the trouble of taking mine apart... Will one from an AW4 work? And what year should I look for so I still have a cable driven speedo? I'm trying to get a mind of what all to order with this thing but geez, so much comes into factor with this swap.
I will have to change the PB. They changed in 91. My three big questions are 1: if I get a newer TCase what will I have to do with it to make it work? Like how do I get my cable driven spedometer to work with an electric spedometer Tcase? 2: is that correct alignment tool? And 3: should I change my brand new slave cylinder again or leave it? Gotta get this parts list finished up haha.
I believe you can change the part on the tcase from electric to mechanical by swapping from old to new.
For the alignment tool, you need to measure the ID of the PB with the OD of the tool.
I don't believe you need to change the slave.  You can keep the one you have.
I just did a ax15 swap using a 1991 ax15 and it had the smaller input shaft, I was using a 1994 engine so I looked up the specs for a 1994 pilot bearing then the specs for the 1991 pilot and has to order a bearing from advanced adapters, then I just went to auto zone and was able to find a Ford clutch tool that was 10 spline and was the right diameter
The speedo is a direct swap. Just make sure it's seated all the way or it won't work. I just learned this today from first hand experience. Lol
Got the tranny. Going to have to weld on a new shift knob connector because they cut the original one off. It's from a rear ended Cherokee. Every gear spins with my hand at the speeds I would think it should. How do you perform a tranny flush? Some dirt got in the transmission because the whole that the shifter goes in had mud in it. Also it needs an output shaft seal, how do I change that? Picking up a 231 from a 91 auto Tuesday. Pictures next.
