I'm looking to rebuild a Dana 44 and put it in the rear of my MJ, what vehicles has an equivalent DISK axle that I can swap in? I'm doing SOA, so I will be welding on new perches.
Some WJs DO have dana 44s, but avoid them, they are aluminum. (Why?) I see JKs in junkyards alot around here, all have Dana 44 rears, with discs, though I don't know if they are the same width as our stock axles.
WJ are about 4" wider than XJ/ZJ/MJ axles, IIRC. JK axles are slightly wider than WJ axles.
IF you want a wider stance, and to run JK wheels, and can get them for a reasonable price you can go that route.
