wutangwisdom Posted July 16, 2015 Share Posted July 16, 2015 So I plan on changing my coolant temp sensor in hope of fixing my stalling issues while shifting only at running temp shifts fine till it warms up. Just wondering If anyone knows the size wrench I need to get the CTS out of its hiding spot , any helpful hints in doing this pita job welcomed. Link to comment Share on other sites More sharing options...
tugalo Posted July 16, 2015 Share Posted July 16, 2015 just leave it where it is and go to the junkyard. Find a 4.0 Cherokee with the sensor in the the thermostat neck and swap out the thermostat neck................might have to get the connector for the sensor so that you can extend your stock wiring. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 16, 2015 Share Posted July 16, 2015 So I plan on changing my coolant temp sensor in hope of fixing my stalling issues while shifting only at running temp shifts fine till it warms up. Just wondering If anyone knows the size wrench I need to get the CTS out of its hiding spot , any helpful hints in doing this pita job welcomed. Why not TEST it first? Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 16, 2015 Share Posted July 16, 2015 So I plan on changing my coolant temp sensor in hope of fixing my stalling issues while shifting only at running temp shifts fine till it warms up. Just wondering If anyone knows the size wrench I need to get the CTS out of its hiding spot , any helpful hints in doing this pita job welcomed.Why not TEST it first? This ^^. Chances are 99.999% the temp sensor is either open (most likely) or shorted. Disconnect the connector and test for an open or short through the sensor with your ohmmeter. Also make sure you have circuit continuity from the CTS output terminal to the Renix ECU. If you don't know how to use a mulltimeter you should learn, especially with a Renix MJ. Link to comment Share on other sites More sharing options...
ScottJeep Posted July 17, 2015 Share Posted July 17, 2015 ^^ A Good Student ^^ studies and along with success...makes the grade ( also known as Renix/MJ ownership )...those that don't well we usually pick over their trucks at the pull-a-part a few months later. Oh... and just so you know I am on your side. DO NOT APPLY ANY SEALANT OF ANY TYPE TO THE SENSOR. Link to comment Share on other sites More sharing options...
wutangwisdom Posted July 17, 2015 Author Share Posted July 17, 2015 Does it matter what year I get the thermo housing with the sensor on the neck from Link to comment Share on other sites More sharing options...
wutangwisdom Posted July 17, 2015 Author Share Posted July 17, 2015 . Link to comment Share on other sites More sharing options...
wutangwisdom Posted July 17, 2015 Author Share Posted July 17, 2015 Sorry for barking ... guess that was a Dumb question Link to comment Share on other sites More sharing options...
wutangwisdom Posted July 17, 2015 Author Share Posted July 17, 2015 No idea what size wrench to get the cts out? Link to comment Share on other sites More sharing options...
