Jackrabbit41 Posted July 9, 2015 Share Posted July 9, 2015 Clutch went out, it's mechanical so hopefully it's just a seal because I found fluid on my pedal, but if it's the sleeve cylinder i just hope it's external. I don't even know what it looks like so not sure what I'm looking for. Thanks Link to comment Share on other sites More sharing options...
FrankTheDog Posted July 9, 2015 Share Posted July 9, 2015 87 will have a internal slave cylinder. If you have fluid on your pedal your master cylinder is the problem and more than likely it is leaking onto your fuse panel and starting to melt it. So your going to want to pull the master cylinder and clean your fuse panel with electrical contact cleaner really well. You may want to pull the carpet and clean it and under it also because the fluid will corrode your floors quick too. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 9, 2015 Share Posted July 9, 2015 What Frank said. Unless you or a prior owner changed the trans, you would have the BA 10/5 with an internal slave cylinder. You can change the master cyl without have to change the slave. Link to comment Share on other sites More sharing options...
Minuit Posted July 9, 2015 Share Posted July 9, 2015 87 will have a internal slave cylinder. If you have fluid on your pedal your master cylinder is the problem and more than likely it is leaking onto your fuse panel and starting to melt it. So your going to want to pull the master cylinder and clean your fuse panel with electrical contact cleaner really well. You may want to pull the carpet and clean it and under it also because the fluid will corrode your floors quick too. This. Link to comment Share on other sites More sharing options...
