MTF fluid??
  On 6/17/2015 at 9:36 PM, Blue88Comanche said:
  On 6/17/2015 at 9:18 PM, Eagle said:
MTF?
Mambo Tango Foxtrot?
WTF does MTF mean?
my best guess is Manual Transmission Fluid.
or My T.A.R.D.I.S. Flooded... The pool in the library might have been a bad idea after all...
Probably a good guess. 71 years on the planet, and this is the first time I've ever encountered gear oil being called "fluid."
WE'RE HERE TO COMMUNICATE! WHY CAN'T WE JUST USE WORDS?
ATF vs MTF    and yes I've seen it before.
but anywho... according to your photo in the other thread it appears you have a Peugeot and that takes regular ol' 75-90 GL-5 gear oil. :thumbsup:
sorry for the lango instead of the lingo this is my first owned 5 speed ( I know pathetic...but at least its a jeep!) so its just refered to as gear oil? ok got it. Ya I got the peugeot. 5.2q expensive drinker. I went to check the level of my gear oil today and realized I didnt have the right sized ratchet so I couldnt check it 3/8 to big and 1/4 to small......
8mm square
http://comancheclub.com/topic/46563-peugeot-ba105-transmission-fluid-change/?hl=square+plug&do=findComment&comment=475051
