Jackrabbit41 Posted June 16, 2015 Share Posted June 16, 2015 Today i joined a big club, the rusty floor plan club but its not that bad (so far). I pulled up the drivers side carpet where your feet sit and theres only surface rust except for a hole the size of a thumb that goes all the way through the wheel well and you can see light. I'm in my last week of school so i don't have time to pull out the hole interior this week, but in a week ill do that and sand all the rust and hope for no more holes but then what should i do? should i get it linex? its easy to clean but expensive and takes a couple days, but then what about herculiner? And other good easy to clean bed liner substance. Can they fill the hole?I've heard thats not easy to clean, but its cheaper. also i would get my bed and wheel wells covered with the linex too cause I've been wanting that, but its just a money thing but ill start working again soon. also, could i just prime and paint it and somehow fill the hole or get something welded on. I'm a first timer with this so give me all the details. and yes I've looked at some other stuff, but still not sure what to do. thanks and here's 4 pics of it. [/url]">http:// [/url]">http:// [/url]">http:// [/url]">http:// sorry for the bad pics i couldn't get it to focus Link to comment Share on other sites More sharing options...
Eagle Posted June 16, 2015 Share Posted June 16, 2015 First step is to determine if the water causing the rust attacked from the underside or the inside (hidden leak). Link to comment Share on other sites More sharing options...
pitbull4x4 Posted June 16, 2015 Share Posted June 16, 2015 You are very lucky with only a small hole. Mine was so bad the floors needed pans both sides. But now I have rust free cab corners, outer and inner rockers and floors. I just sprayed bed liner on floors Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 16, 2015 Author Share Posted June 16, 2015 On 6/16/2015 at 12:57 AM, Eagle said: First step is to determine if the water causing the rust attacked from the underside or the inside (hidden leak). Pretty sure it was from outside cause the previous owner bed lined the well wheels but right where the rust was there was none and plus the paint on the inside was ok while the outside was all rust Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 16, 2015 Author Share Posted June 16, 2015 Could I just jb weld it then get linex out over it? I've seen linex work mircles so I think that'd be strong wnough Link to comment Share on other sites More sharing options...
Incommando Posted June 17, 2015 Share Posted June 17, 2015 Does Line-X stop rust? If it was from the outside you would need to strip the pan completely and coat it from that side Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 17, 2015 Author Share Posted June 17, 2015 On 6/17/2015 at 7:39 AM, Incommando said: Does Line-X stop rust? If it was from the outside you would need to strip the pan completely and coat it from that side I think that I am just gunna cut out the rust spot, get a patch welded in and paint the whole thing and make sure it's sealed up and then finish it over with plastidip spray cause I've had that stuff work wonders Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 17, 2015 Author Share Posted June 17, 2015 Maybe get linex in the future. I've watched some videos and it seems pretty easy to weld in a patch. I just need to get a welder and hopefully that's my only hole Link to comment Share on other sites More sharing options...
Incommando Posted June 18, 2015 Share Posted June 18, 2015 On 6/17/2015 at 5:20 PM, Jackrabbit41 said: Maybe get linex in the future. I've watched some videos and it seems pretty easy to weld in a patch. I just need to get a welder and hopefully that's my only hole Great answer Link to comment Share on other sites More sharing options...
