Aftermarket TPS's.
Has anyone ever had trouble with aftermarket Renix TPS's? When this problem with my Jeep started, the first thing I changed was the TPS. Because my factory one was failing. With the factory TPS the truck would try to stall out EVERY rev of the engine. So then I bought an Airtex one. The Airtex lasted a total of... 10 minutes. Would have to be adjusted every time I turned off the engine. Worked fine after adjusted. But as soon as the engine turned off it had to be adjusted again or the engine would stall after revved. Now, I have a Standard Motor Products one. Not the cheap "T" series, but the slightly more expensive Auto tranny one (my Jeep is a stickshift though). And now the Jeep will only stall out if warmed up, turned off for about 10 minutes, and cranked again. Then it only stalls the first time its revved. And I have a seemingly low idle with slight backfires when warmed up. I've checked and changed almost everything else on this Jeep that could cause this problem. And my mind just keeps going back to ANOTHER aftermarket TPS being faulty. But the TPS passes the test. It can be adjusted to the correct setting and everything. Has anyone ever had a problem with aftermarket TPS's? I know that aftermarket CPS's are a no no. What about the TPS?
Thanks!
I've been running my Standard Motor Products TPS for over a year now with no problems.
What kind of resistance are you getting on the TPS ground?
Some of the problems you are describing sounds more like a fuel related issue.  Very similar to the problems I was having when the hose from my pump to the hanger was not seated.
Mopar is what I should have gotten but I was trying to save a buck... I checked the resistance when all of tbis started and it was how it should be. Didn't fluctuate when I wiggled the wires, either. I've changed the entire fuel system. Pump, sending unit, regulator, injectors, and filter. The problem was happening before I changed the pump but I do need to check the line. I made sure it was tightened good when I installed it but who knows, stuff can.happen. And running with the TPS disconnected? You can do that? I didn't know it would run without.
Trust me............
I just got my new throttle body installed so I might try tomorrow. Anything I should expect or be looking for while it runs without a TPS?
