SOA in the back, what for the front?
  On 5/14/2015 at 11:34 PM, Pete M said:
couldn't find the image I was looking for so i made my own. apologizes for the crudeness. I know there are better versions out there and will include a better one if I can find it.
red is the lower control arm. black is the arc of suspension travel. arrow indicates the immediate direction of travel up once the tire first contacts a positive obstacle (meaning a rock rather than a hole). Jeep is traveling to the right.
The left image is a stock suspension. note that the direction of travel is up and then back, effectively absorbing the impact with the spring. the middle is a lifted suspension. note the forward direction of travel which jolts the truck up a bit before the spring absorbs the impact. The image on the right is the same lift but using a bent arm. note that the arc and direction of travel is exactly the same as the middle image.
Thanks. That makes sense
No need for a SYE or t case drop due to the long wheel base of the MJ. You shouldn't need shims if you're doing an axle swap. Just set the pinion angle to what it should be. If you do need them, most any off road parts website should sell them.
