hassyfoto Posted May 13, 2015 Share Posted May 13, 2015 91 Comanche Ok, the problem is the right turn lamp blinks very slow during the day and when the running lights are turned on the right blinker almost does not work at all. It may blink once every 40-45 seconds. This is what I have preformed; Checked the grounds on the rear of the truck, under the hood and under the dash. Cleaned the metal and cleaned the grounds. Replaced the bulbs several times. I made sure both sides has the same bulbs made from the same company Checked to make sure there is power to the right lamp & there is! Replaced the fuses, several times just to make sure. Checked the wire harness under the bed for cuts, loose connections, etc... I did not see anything that appeared damaged, worn or rusted Since some of the obvious problems are already addressed, what are some other possibilities. Could this be a turn signal harness issue inside the steering column? Looking for answers from someone that has had a similar issue. thanks Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted May 13, 2015 Share Posted May 13, 2015 Have you switched the turn signal flasher with the 4way flasher ? Also check the connection for the front lighting harness at the air box on the drivers side , may be corroded inside . Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 13, 2015 Share Posted May 13, 2015 When I replaced both front turn signal sockets, all my turn signal gremlins went away. Problem is they corrode internally, cause ground issues, which affects how the rest of the other turn brake tail lights operate. Good replacements in the "help" section of most parts stores. Link to comment Share on other sites More sharing options...
hassyfoto Posted May 15, 2015 Author Share Posted May 15, 2015 I will check the sockets & the 4-way this weekend. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 15, 2015 Share Posted May 15, 2015 I had the exact same problem, replaced the socket as 64 Cheyenne advised and that solved it. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 16, 2015 Share Posted May 16, 2015 Front sockets....they're the ones with the grounding issues that cause all the problems. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 16, 2015 Share Posted May 16, 2015 Why would bad front sockets only affect the right rear? Replace the socket that's giving you problems and go from there. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 16, 2015 Share Posted May 16, 2015 Because the fronts short out to ground, causing all kinds of mayhem. Ohms law. Link to comment Share on other sites More sharing options...
schardein Posted May 16, 2015 Share Posted May 16, 2015 I read this. Remembered I had the same issue. Also did most of the same fixes. Went out and checked, but it is not doing it anymore. About a month ago I replaced my entire front lighting harness with one that had factory fog light wiring (got it from the junkyard). Cleaned all the terminals at the main harness connection behind the driver headlight, both the truck side and light side. I can only conclude that is what fixed it. Link to comment Share on other sites More sharing options...
