HOrnbrod Posted April 27, 2015 Share Posted April 27, 2015 Alright, I admit an A/C idiot and I'm not ashamed. :rotfl2: My original R12 compressor seized up, and I'm going to convert to R134A refrigerant since I'm out of R12. I already have a NOS R134A compressor I picked up a few years ago as I knew this day would arrive sooner or later. What other A/C parts do I need for the conversion? My plan is to install everything I have to, then bring it to a shop for charging. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 27, 2015 Share Posted April 27, 2015 O-rings and expansion valve......that's it. Oh yeah.......you gotta clean out all the R12 before you add 134a. I flushed mine with mineral spirits then flushed that with denatured. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 27, 2015 Author Share Posted April 27, 2015 That doesn't really tell me much since I know zero about A/C. Care to elaborate? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2015 Share Posted April 27, 2015 You need to replace the receiver / drier , which is the cylinder located by the alternator with the sight glass on top of the cylinder . You also need to replace the expansion valve which is the block located where the 2 AC hoses connect at the firewall .Buy some AC flush before putting the new parts on and pour the flush in the rest of the AC system , follow the directions as to how long to leave the flush in then blow it out with an air gun . As far as the new compressor goes it will have a small amount of oil in it but not enough for the entire system and you or the AC shop will have to add more . When replacing all the orings make sure you coat the orings with the PAG oil ( refrigerant oil ) . The AC shop will run a vacuum test to make sure it does not have a leak before filling with refrigerant and PAG oil. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 27, 2015 Share Posted April 27, 2015 It's also worth noting that the 134a system runs at a higher pressure than a r12 system and in some cases the hoses need to be changed with barrier hose . You will only need to put 70-80% of the recommended r12 amount with 134 a . Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 27, 2015 Share Posted April 27, 2015 Yeah, I forgot about the dryer. Valve and dryer are fairly cheep though, under $20 each at Rockauto. As for the hoses, you'll find no problem locating the hoses for the 4.0, they don't exist for the 2.5, however, I see little difference in them. They are expensive, IIRC. I contacted Jeep Air in FL at the time and they told me to use my existing hoses, that the 'barrier hoses' were a nonsense ploy to sell new hoses. Link to comment Share on other sites More sharing options...
Marine1Texas Posted April 27, 2015 Share Posted April 27, 2015 new expansion valve, new dryer, and new seals. after you have system installed and closed, use a pump to take out all air and moisture. let it sit for 15 minutes at zero to make sure seals are holding. if holding good then put a small can of 134a oil in and then you can fill. seen. Link to comment Share on other sites More sharing options...
dj5 Posted April 27, 2015 Share Posted April 27, 2015 i bought a universal adapter from advanced and put it on my fill line and filled her up...still works fine 3 months later. Link to comment Share on other sites More sharing options...
Bobolink Posted April 27, 2015 Share Posted April 27, 2015 When my compressor went belly-up 5-6 years ago (seals were shot and refrigerant was gone), I bought the equipment to do the whole project myself. I stuck with R-12, because I, like you, had purchased a 15 lb. can of R-12 back when one still could. I replaced the compressor, receiver/dryer, expansion valve, and all the hoses. If I recall correctly, I also replaced the condenser, though I don't remember why (it shouldn't be necessary). I had a flush canister to flush the evaporator core (everything else was new), and blew it out with an air gun, then put it on a vacuum pump for 30 minutes to ensure that the system was completely dry, and filled 'er up with R-12. The vacuum pump and R-12 canister hooked to the system through a manifold with gauges. Haven't had to touch it since. If you still have the original 24 year-old A/C hoses on there, I would recommend replacing them, along with the filter/drier and expansion valve. I would guess that I still have about half the canister of R-12 left if I ever need it. Link to comment Share on other sites More sharing options...
sloride Posted April 27, 2015 Share Posted April 27, 2015 Don, I vote you replace everything so you reduce the possibility of your compressor Shooting craps from the dreaded 'black death'. Small price to pay for piece of mind starting with a whole new system. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 27, 2015 Author Share Posted April 27, 2015 Thanks guys. Link to comment Share on other sites More sharing options...
