1987 comanche first car
  • Replies 335
Just got myself a 1995 2 door 4x4 Cherokee with a manual tranny. Using it for parts. The doors are manual windows and locks so I'm leaving those on but I'm taking out the motor tyranny Seats and brake booster. Pics coming tomorrow
Awesome "first car" :yes:
you're off to a great start.
Just took her for a spin around the block. She runs good but the battery is totally shot. I was hoping it had 4.10s but both of the tabs that say on the diff are gone so I don't know what It has
1995 Manual Transmission XJ?
if it's a 4.0L it would have 3.07's
if it's a 2.5L it would have 4.10's
If it's really a D44, it must have been swapped in my a previous owner.
Factory installed XJ Dana 44's were long long gone by 1995,
so it's anyones guess what gears it has.
More likely it's an Dodge 8.25" axle
then with the manual trans, it's 3.07's, or 4.10's depending on which engine it has.
Good luck and keep posting pics
Ya it's a manual 5 speed with an ax15 (that's why I got it) and it has a 4.0. I thought it was a Dana 44 just cause it looked bigger then a 35 but I really had/have no idea
Anything could have been swapped in,
but I'd guess for that year and combo it's a 3.07 geared 8.25" axle.
8.25 is bigger than a D35, has C-clips, and a flat bottom.
Pics of all the different diff covers have been posted here before, but are easy to find online.
You could also look at the brakes.
8.25's usually have small/wide brake drums (9"x2.5")
85-89 Comanches/Cherokees like yours should have come with 10x1.75" drums.
 You can tell the difference between the two from the outside.
D44's would likely have 10"x2.50" drums
today is monday, and ever since friday I've been doing the ax15 swap. its been going well, no issues until yesterday, sunday, when we found out about the PB and the different size. today, monday, i went to a machine shop and had a new brass bushing made for 35$, which was sweet and only took 30 mins. hopefully i can have the clutch and flywheel back on in the next hour or so and then start putting her back up in the comanche. Also, do all of the comanche plugs, and breathers fit on the ax15? or do i need to do some wiring?. thanks!
I also got to borrow a tranny jack from work, Imco Construction, and that has been really helpful so far.
[/url]">http://
new brass bushing
[/url]">http://
[/url]">http://
had to get a new impact wrench. really handy because its small. 450 foot pounds
[/url]">http://
pugeout removal
[/url]">http://
all cleaned up
[/url]">http://
flexing out on some stuff at work. had the quad in the back too so it was a little tippy.
[/url]">http://
[/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image1_zpsdnoiuyjw.jpeg.html'>
tranny is all in. I started school right in the middle of it so i didn't get to finish it until the following saturday. it went well other then i might have an oil leak and i couldn't get a U-Joint all the way seated in so i had to take it to a shop but it was free so that was dope. this oil leak is just worrying me. it could be the oil pan gasket because i didn't put any sealant on the corners of it like the directions said (didn't read them until it was all said and done) or hopefully not the rear main. i replaced it and had no problems with it. maybe I'm wrong about this oil leak. ill just have to keep monitoring my oil levels.
Finally got around to posting some more stuff. So far, the tranny is running great. I still have out the new 4wd linkage on and i still need to connect my 2 piece axle. Because school started I haven't been working so my income base come to a stop. Because I'm out of $$$ I've been working on my parts cherokee and 8.8. I pulled both axles and brake booster out of the cherokee and then had it picked up for free. I welded the axle tubes to the housing on the 8.8. I preheated the housing to 400 and spot welded it so hopefully it'll hold up.  I also got a DIY diff cover for the 8.8 and I love how it looks and turned out. The paint I'm using on the axles is rustoleom hammered black. My next project is to finally get the 8.8 in, the new lift, and this dana 30 that needs some work. I'm going to paint it tonight and then take it to get re geared soon. It need some new brakes so ill probably just by factory ones from napa. I'm going to paint this 8.25 i got too and try to sell it. Thanks y'all!!
[/url]">http://
[/url]">http://
[/url]">http://
I sold the u bolts so moving the cherokee around was a pain. I end up having to use 2 winches and an engine lit to get it over this 2 inch curb and into my "work zone". At one point the axle was underneath the rear doors.
[/url]">http://
[/url]">http://
[/url]">http://
[/url]">http://
[/url]">http://http://s1148.photobucket.com/user/Jackrabbit123/media/image8_zps3wzdbnsp.jpeg.html'>
Well, I was playing football with my buddies and afterwards I was heading out of the parking lot and did a donut. There was no people or cars around. Got reported, the pulled over, and almost got a reckless driving charge. This was on a college campus and now I can't ever go back anywhere on it (thus college campus is 1/4 mile away and I go there many times a month so it sucks). I know I should be thankful I didn't get reckless but man I'm still pissed. Who hasn't done a donut in a empty parking lot? My sister has in her Jetta. Just adds character to my Comanche. Lol
LOL wtf jack.
Man that sucks, At least you didnt get charged for reckless driving.
I'm going to try and get a trip to sumas mt planned early next month.
Need to try out the new front axle & Cage.
LOL wtf jack.
I went to walker valley for my third time yesterday (Saturday) and I went in some jeep trails there. It's nice becuase they are all labeled and have names. After I do my axle swap I'm wanting to go there and hit some of the trails I rode on my quad. A lot of trails have too tight of corners for our long beds
LOL wtf jack.
Yea, I've only gone up their once.
Don't wheel your truck up there without someone with you, Its really easy to get stuck.
LOL wtf jack.
Ya I'd never go out without another person
  • 3 weeks later...
Finally ordered a headliner. I'm missing everything so it was 225$ From sms headliners.
/edit 10/15
Also got some Bosch injectors coming
Did you ever get your axle back yet?
No. They were supposed to call me last Friday when it was done but they never called. I'm going to go there today and see what's up
