Jeep Driver Posted March 30, 2015 Share Posted March 30, 2015 http://tampa.craigslist.org/pnl/pts/4896297012.html Link to comment Share on other sites More sharing options...
dunnc1991 Posted April 1, 2015 Share Posted April 1, 2015 Doesn't seem to know what he actually has Link to comment Share on other sites More sharing options...
88whitemanche Posted April 1, 2015 Share Posted April 1, 2015 I know the first diff with the flat bottom determines a 8.25 upside down The 2nd diff is a dana 35.... Idk about the third diff... Link to comment Share on other sites More sharing options...
Bonkers Posted April 3, 2015 Share Posted April 3, 2015 Whats special about an AMC20? Link to comment Share on other sites More sharing options...
88whitemanche Posted April 3, 2015 Share Posted April 3, 2015 Rare option to the comanches and comes with a 1-pce axle shaft design...some here say it's stronger than the comanche 44.... Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 14, 2015 Author Share Posted April 14, 2015 I know the first diff with the flat bottom determines a 8.25 upside down The 2nd diff is a dana 35.... Idk about the third diff... Ahhhh........that's what it is....thanks. Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 14, 2015 Share Posted April 14, 2015 There are two D35s out of XJs and a 8.25 laying there. If you check the add again he updated the picture of the axles. You can see the XJ shock mounts on the rear D35s. If you look real close at the 8.25 you will see where the paint was ground off to weld on the spring perches. I'm not sure what the ratio is on it as 3.38 wasn't a offered ratio. Link to comment Share on other sites More sharing options...
