cam and crank alignment problem
So if I align at tdc. How can I get my cam to align right with it
It has to be at TDC with the #1 cylinder on the compression stroke. You may have it on the exhaust stroke. Then you count the number of links between the mark on the crank sprocket and the mark on the cam sprocket. How to set that is in the FSM.
Yes I got a new timing chain and sprockets I set #1 cylinder to tdc on compression stroke. I aligned my camshaft with the dot on the crank. My distributor rotor was pointing to #6 I believe. Before all this happened the truck jumped time and I didnt know it I took the whole distributor out and now I'm let where I'm at now. New distributor new timing chain and sprockets new rotor new cap new plugs new wires. But I can't get the dang thing to fire right
when I manual set the distributor to number one and line all marks up.
Bringing #1 piston to TDC does NOT mean  you are on the compression stroke, the cam determines the compression or exhaust stroke.
What makes you think you 'jumped time'?
As pointed out by Jeep Driver, being at TDC does not mean you are on the compression stroke. In fact, if your distributor was pointing at #6 with the piston at TDC, I'd guess you are on the exhaust stroke. The firing order for an in-line 6 is 1-5-3-6-2-4. Notice that #6 corresponds to #1, but on the second go-round for the crank in one full cycle (two revolutions).
Either that, or you didn't index the new distributor properly when you installed it. The housing itself can't be adjusted (unless you follow Hornbrod's procedure and grind off the indexing tab, but that should be the LAST resort, not the first). If you're certain the #1 cylinder is at TDC and is on the compression stroke, then you'll need to pull the distributor and realign the drive gear by a couple of teeth until it points at the #1 turret on the distributor cap.
What "grinding"? No grinding necessary for a stock cam. Just pull the dizzy, rotate 180* according to the procedure, then see if it fires up.
You should not need to cut the "ears" to correctly position the distributor unless you've installed an aftermarket camshaft.
I literally just went through this. New engine. The distributor was not aligned. I pulled the distributor out. I put cyl 1 at TDC, and made sure crank was at 0*. I could not get the rotor to line up exactly with #1 on the cap. I kept moving the oil pump, and re seating, but it would always be just before or just after #1.
Turned out it was 180 off. rotated engine till a puff of air came from the spark plug hole of #1 cyl, moved crank pulley to 0*, moved oil pump gear to 11 o-clock, and installed distributor. dropped right into place. dead on with #1 cyl on cap. centered.
I have an aftermarket cam, no notching needed for my install.
I did cut the cap, to see rotor, but later I discovered just painting a small white line on the distributor  body where cyl1 is, was easier. Also marking the small "cut" on the crank pulley mae it really easy to see an align to 0*.
I'm an idiot I thought the exaust stroke was blowong out air in fact it was but not near as much as the second go around on compression. I was 180 off the whole time. Thanks guys and does anyone know where and the part numbers for all the vaccuum lines and pcv? All my plastic hoses arw brittle and the rubber ones are dry rotted.
glad you got it fixed. On the hoses and vac lines, I was looking for that too. never found a complete set. I just pulled the hard lines from a pick n pull. And bought an assortment of vac lines at auto stores.
