Strange vibration under no engine load
Hope you guys can point me in the direction to solve this issue. It's a '90, 4.0L, AX-15, 2WD. When I'm driving and lift off the accelerator, the MJ starts vibrating. Even if I throw it into neutral the vibration is there. It only happens when I'm completely off the accelerator, any load on the engine and it goes away. I don't feel it in the steering wheel (just the seat of my pants) or while not moving. All help is appreciated.
  • 1 month later...
You guys were right on the money, the front u joint was AFU. Two of the caps were dry as a bone, cracked and missing ALL their needle bearings. I bought the Harbor Freight 20 ton press for $150, made pressing them out/in a piece of cake! Thanks for the help.
Massive overkill...
Yeah, but it will also make pressing wheel bearing races a snap, among other things. Remember I have three of these beasts to keep on the road and it was only $150 with the March coupon! Plus it's another tool.
