Factory shift light not working
My question is why? Everybody knows those lights "LIE" did you ever try and always shift when the light says to upshift?
Probably won't keep doing it for long (shift when light comes on) and will probably overlook it soon, and then probably maybe wish you would have never put the effort into makin the durn thing work. IMO useless like the service reminder, or do you need that to work also? :rotf:
I actually noticed I have a shift light on my 86 2.5 the other night. Apparently some previous owner covered the light with something and enough had worn off I could see the glow in the dark.
Now my question is what triggers the light? The dang light would glow when going up hill when, in fact, I needed to down shift.
I know my TJ has an up shift light, but after 11 years I don't see it anymore.
is it adjustable in any way?
I wouldn't worry too much about the light not working. My 88 had it, it did not work all the time and I rarely used it to know when to shift. I found shifts were smoothest when I shifted at 1,500 rpm or 2,500 rpm. Small city here, so I mainly shifted at 1,500 rpm around town.
The light is not triggered by the speedo but by the engine vacuum ......on the AX tranny;s there is a 5th gear switch that de-activates the light in 5th ( cuz if it didn't you would try to shift into 6th  :doh: )
