Noise from rear
Sorry for bugging yall but my jeep has seemed to of had developed a new issue and I need help identifying what it is ): . It sounds sounds sorta like a brake lath or kinda like a hissing metal noise , it has the sound while driving , or while coasting in neutral. (Dana44 tracklok ) I took a vid of the noise while pushing the truck with the engine off . https://vimeo.com/115887193
Thanks in advance :)
There is very little clearance between the brake drum and the dust shield. If the dust shield gets bent it can rub up against the brake drum and cause a constant raspy metal sound.
Or your brakes could just need replacing.
Does the sound start as soon as you begin to move?
Have you noticed the truck dragging when you let off the accelerator, as if the brake is applied slightly?
When did it start? Have you taken the truck off road recently?
...but I would go ahead and do a rear brake job. Everything looks pretty rusty in there.
Every drum brake equipped vehicle in these parts has rusty brake drum bits. Looks normal I don't even see the rust LOL - lots of life left on those shoes.
