I have a 1991 4.0 Comanche that has a 88 Cherokee motor swap.  When it was swapped everything on the old 91 was put on the 88.  Now it won't start.  We changed the computer, dizzy, cap and rotor, wires, tried two new cranks sensors and flexplate.  It will crank but not fire.  The spark goes
snap snap         snap snap        snap snap.  Anyone have any ideas why it won't spark like it should?
If you're using the flexplate for an '88, it won't work with the '91. You need one that matches the electronics, so if you've got the HO computer and everything for a '91, use a flexplate for a '91, but if you're running Renix electronics, you'll need the Renix flexplate.
Another member on here a long while ago was having issues with new flexplates not having windows in the correct spots, but I don't remember if it was for Renix or HO. I replaced my cracked flexplate in March with a cheap one from RockAuto that worked perfectly in my '91.
It might not do you much good if the motor's never been started, but have you tried checking for codes?
In your list of things that you have not replaced is the coil itself. Just a few bucks off of Rock Auto. A timing light on the coil wire will show if its pulse is erratic.
