1JTHA661XGT104391 (?)
1986 Jeep Comanche
Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase
2.5 4cyl, column shifted auto, 2wd, Dana 35(?)
Harrys U-pull-it, Hazleton PA
Sitting in said junkyard.
Blue interior, body is shot to hell as are the floors, base model cluster, column shifter readout was on the floor when I saw the truck, all interior panels were behind the seat, accidentally broke the rear slider trying to remove it ;_;, Tailgate gone, rear bumper non-salvageable (cut at the mounts for some reason), 2.5 4cyl with Vbelts.
  • 3 months later...
  • 1 year later...
  • 2 years later...
  • 1 year later...
1 minute ago, JMO413 said:
VIN not good last 8 pulls an XJ
I wonder if I caught that and didn't think to put the real VIN. Or was the build date correct for the XJ but not the MJ?
You put in the build for the XJ.
Lol, I mustve been in one of those concentrated modes of mine and completely missed that. Hopefully when ill return ill goof around with some of the broken VINs and see if I can find the right ones.
I thought about it. Trying to get through the 86's first.
Yeah I see that. I feel bad for both you and jdog having to do the build sheets for 86-88 when I did the dates.
