dustyinthedirt Posted December 2, 2014 Share Posted December 2, 2014 i was searching through the forums and stumbled apon the parking brake recall and decided to see if my year is on the list. while searching i found this 1990 Jeep Comanche Recall Item Affected: VEHICLE SPEED CONTROL: CRUISE CONTROL Date Announced: 01/04/1991 Description of Recall:MALFUNCTION OF FUEL INJECTION SYSTEM THROTTLE POSTITION SENSOR COULD CAUSE INTERMITTENT HIGH ENGINE IDLE SPEED IMMEDIATELY AFTER STARTING ENGINE. Action Need To Fix It:REPLACE THROTTLE POSITION SENSORS WITH SENSORS THAT WOULD SEND CORRECT SIGNALS TO THE FUEL INJECTION SYSTEM. FIND YOUR LOCAL Jeep Service Center when i start my truck it revs to about five thousand and then quiets back down to normal. i found this on the website http://www.dealerrater.com/recalls/Jeep/Comanche/ there are many other recalls as well on these things Link to comment Share on other sites More sharing options...
Blue XJ Posted December 2, 2014 Share Posted December 2, 2014 It could be that, it could also be a faulty and/or dirty/sticky IAC on the throttle body. Link to comment Share on other sites More sharing options...
MuddFoot Posted December 3, 2014 Share Posted December 3, 2014 I'm with blue xj on this. i don't think you still have the factory tps unless you have owned it from day one..... Link to comment Share on other sites More sharing options...
joester1908 Posted December 3, 2014 Share Posted December 3, 2014 Try adjusting your TPS with a multimeter. If you can't get it in the correct range, then I'd say start thinking about replacing it. They're right, most likely it has been replaced already. Link to comment Share on other sites More sharing options...
joester1908 Posted December 3, 2014 Share Posted December 3, 2014 Link to TPS adjustment, just in case you need it. http://www.naxja.org/forum/showthread.php?t=1072534 Link to comment Share on other sites More sharing options...
cruiser54 Posted December 6, 2014 Share Posted December 6, 2014 Link to TPS adjustment, just in case you need it. http://www.naxja.org/forum/showthread.php?t=1072534 That is also right here on Comanche Club along with 26 other mostly Renix Tips. Click the link below. Link to comment Share on other sites More sharing options...
