redwolf624 Posted November 24, 2014 Share Posted November 24, 2014 so as we all know i'm 2wd but still take my MJ mudding, well the last two times i've done it i've sucked in water/mud and messed up my carb, is there anyway to somehow seal my system to where i can mud and not suck in everything, i know i can't exactly seal off the air cleaner but what could i do to reduce my chances or messing stuff up when i do mud, Redwolf Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 24, 2014 Share Posted November 24, 2014 Your best bet to keep mud out of the carb is ...stop mudding. :yes: Link to comment Share on other sites More sharing options...
Eagle Posted November 24, 2014 Share Posted November 24, 2014 ..., is there anyway to somehow seal my system to where i can mud and not suck in everything, ... Redwolf Snorkle Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 24, 2014 Share Posted November 24, 2014 Link to comment Share on other sites More sharing options...
Lee21490 Posted November 24, 2014 Share Posted November 24, 2014 Is that... House gutter drains? :rotf: Link to comment Share on other sites More sharing options...
nitroxsteve Posted November 24, 2014 Share Posted November 24, 2014 If your getting mud in the carb I would be more concerned with mud (dirt and water) that is getting into the engine through the carb. Do you have the factory air cleaner or an open element? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted November 24, 2014 Share Posted November 24, 2014 Is that... House gutter drains? :rotf: Total cost = $12.95 Comic Relief= priceless Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 24, 2014 Share Posted November 24, 2014 Is that... House gutter drains? :rotf: Yes, it's gutter, but it's the expensive heavy duty vinyl stuff. And notice the cone filter that keeps birds, bugs, and squirrels out. :rotfl2: Link to comment Share on other sites More sharing options...
Blue XJ Posted November 24, 2014 Share Posted November 24, 2014 I thought it was to keep the leaves out of the gutters? Link to comment Share on other sites More sharing options...
benjy_26 Posted November 24, 2014 Share Posted November 24, 2014 Hell, if it works.... Link to comment Share on other sites More sharing options...
benjy_26 Posted November 24, 2014 Share Posted November 24, 2014 If it were me, I'd look for something like this: http://www.spectreperformance.com/mobile/product.aspx?prod=755 Then do the "windstar mod". http://www.jeepforum.com/forum/f9/windstar-cowl-intake-1117102/ Link to comment Share on other sites More sharing options...
redwolf624 Posted November 24, 2014 Author Share Posted November 24, 2014 Your best bet to keep mud out of the carb is ...stop mudding. :yes: i can't just stop mudding, that's like tellin someone to stop smokin :rotf: ..., is there anyway to somehow seal my system to where i can mud and not suck in everything, ... Redwolf Snorkle i've thought about a snorkle but that still doesn't stop the fact of the water that gets on top of the air cleaner If your getting mud in the carb I would be more concerned with mud (dirt and water) that is getting into the engine through the carb. Do you have the factory air cleaner or an open element? i do have the factory air cleaner if a air cleaner hose from the cleaner to the grille If it were me, I'd look for something like this: http://www.spectreperformance.com/mobile/product.aspx?prod=755 Then do the "windstar mod". http://www.jeepforum.com/forum/f9/windstar-cowl-intake-1117102/ top one would be nice for a snorkle, bottom would be great untill i flood out, Redwolf Link to comment Share on other sites More sharing options...
nitroxsteve Posted November 25, 2014 Share Posted November 25, 2014 If the problem is water leaking in around the wing nut just seal the wing nut wit silicone. You will need to reseal it every time you open it but it will work. Also remember your not messing up youcarb you are messing up your engine and running the chance of hydro locking it. If you are going to continue swamping the truck water proof it or set some money back for more junk yard engines. Link to comment Share on other sites More sharing options...
benjy_26 Posted November 25, 2014 Share Posted November 25, 2014 Your best bet to keep mud out of the carb is ...stop mudding. :yes: i can't just stop mudding, that's like tellin someone to stop smokin :rotf: ..., is there anyway to somehow seal my system to where i can mud and not suck in everything, ... Redwolf Snorkle i've thought about a snorkle but that still doesn't stop the fact of the water that gets on top of the air cleanerIf your getting mud in the carb I would be more concerned with mud (dirt and water) that is getting into the engine through the carb. Do you have the factory air cleaner or an open element?i do have the factory air cleaner if a air cleaner hose from the cleaner to the grille If it were me, I'd look for something like this: http://www.spectreperformance.com/mobile/product.aspx?prod=755 Then do the "windstar mod". http://www.jeepforum.com/forum/f9/windstar-cowl-intake-1117102/ top one would be nice for a snorkle, bottom would be great untill i flood out, Redwolf Damn. You run that deep in 2wd? Link to comment Share on other sites More sharing options...
redwolf624 Posted November 25, 2014 Author Share Posted November 25, 2014 If the problem is water leaking in around the wing nut just seal the wing nut wit silicone. You will need to reseal it every time you open it but it will work. Also remember your not messing up youcarb you are messing up your engine and running the chance of hydro locking it. If you are going to continue swamping the truck water proof it or set some money back for more junk yard engines. never thought about the wing nuts with silicone, how bout the over lip on the air cleaner top? Your best bet to keep mud out of the carb is ...stop mudding. :yes: i can't just stop mudding, that's like tellin someone to stop smokin :rotf: ..., is there anyway to somehow seal my system to where i can mud and not suck in everything, ... Redwolf Snorkle i've thought about a snorkle but that still doesn't stop the fact of the water that gets on top of the air cleanerIf your getting mud in the carb I would be more concerned with mud (dirt and water) that is getting into the engine through the carb. Do you have the factory air cleaner or an open element?i do have the factory air cleaner if a air cleaner hose from the cleaner to the grille If it were me, I'd look for something like this: http://www.spectreperformance.com/mobile/product.aspx?prod=755 Then do the "windstar mod". http://www.jeepforum.com/forum/f9/windstar-cowl-intake-1117102/ top one would be nice for a snorkle, bottom would be great untill i flood out, Redwolf Damn. You run that deep in 2wd? i aint afraid to try anything once plus if i have a buddy with a tow point i'll get out some how, normally when i mud i don't think of the aftermath, Redwolf Link to comment Share on other sites More sharing options...
Eagle Posted November 25, 2014 Share Posted November 25, 2014 never thought about the wing nuts with silicone, how bout the over lip on the air cleaner top? A decent snorkle arrangement will not use the factory air cleaner, it will use something that can provide a decent seal. i've thought about a snorkle but that still doesn't stop the fact of the water that gets on top of the air cleaner Yes, it does. i do have the factory air cleaner if a air cleaner hose from the cleaner to the grill No good. See above. i aint afraid to try anything once plus if i have a buddy with a tow point i'll get out some how, normally when i mud i don't think of the aftermath, Time to start thinking about the aftermath. Didn't you just go through an engine swap to get your truck running again? Do you want to do that again? Even if you don't hydrolock it, every time you suck in mud you're effectively abrasive blasting the interior of your engine. You're going to destroy it. It's just that simple. Water on the top (outside) of the air cleaner wing nut is NOT your problem. It's a lot more serious than that. You need a good snorkle that will relocate the carburetor air intake up high enough that you won't be sucking in mud and water. You need something like this: http://www.rocky-road.com/jeep-cherokee-snorkel.html Link to comment Share on other sites More sharing options...
redwolf624 Posted November 26, 2014 Author Share Posted November 26, 2014 never thought about the wing nuts with silicone, how bout the over lip on the air cleaner top? A decent snorkle arrangement will not use the factory air cleaner, it will use something that can provide a decent seal. i've thought about a snorkle but that still doesn't stop the fact of the water that gets on top of the air cleaner Yes, it does. i do have the factory air cleaner if a air cleaner hose from the cleaner to the grill No good. See above. i aint afraid to try anything once plus if i have a buddy with a tow point i'll get out some how, normally when i mud i don't think of the aftermath, Time to start thinking about the aftermath. Didn't you just go through an engine swap to get your truck running again? Do you want to do that again? Even if you don't hydrolock it, every time you suck in mud you're effectively abrasive blasting the interior of your engine. You're going to destroy it. It's just that simple. Water on the top (outside) of the air cleaner wing nut is NOT your problem. It's a lot more serious than that. You need a good snorkle that will relocate the carburetor air intake up high enough that you won't be sucking in mud and water. You need something like this: http://www.rocky-road.com/jeep-cherokee-snorkel.html i've looked at safari snorkels before but never really thought much of them as i have a carb, but now the snorkels i was lookin at do seem like a good idea i just don't know how the mount up, i always see them goin up the side of a windshield of jeeps, Redwolf Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2014 Share Posted November 26, 2014 i've looked at safari snorkels before but never really thought much of them as i have a carb, but now the snorkels i was lookin at do seem like a good idea i just don't know how the mount up, i always see them goin up the side of a windshield of jeeps, That's where they run. The purpose is to get the air inlet up high enough, and perhaps facing to the rear, so the intake is above any water or muck that you're likely to encounter. Link to comment Share on other sites More sharing options...
redwolf624 Posted November 27, 2014 Author Share Posted November 27, 2014 i've looked at safari snorkels before but never really thought much of them as i have a carb, but now the snorkels i was lookin at do seem like a good idea i just don't know how the mount up, i always see them goin up the side of a windshield of jeeps, That's where they run. The purpose is to get the air inlet up high enough, and perhaps facing to the rear, so the intake is above any water or muck that you're likely to encounter. well i guess if i can't sell the MJ, and can fix it, it's project snorkel, Redwolf Link to comment Share on other sites More sharing options...
