54bobby Posted December 8, 2014 Share Posted December 8, 2014 could you have bad gas? a crimped fuel line? Link to comment Share on other sites More sharing options...
wombat Posted December 8, 2014 Author Share Posted December 8, 2014 I was thinking bad gas, so I contacted the PO to see how long it was sitting before I got it. He said it was only 7 months. But I might trydraining it anyway. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 8, 2014 Share Posted December 8, 2014 Where's the level at now? Maybe just add gas? Link to comment Share on other sites More sharing options...
wombat Posted December 8, 2014 Author Share Posted December 8, 2014 1/2 tank Link to comment Share on other sites More sharing options...
cruiser54 Posted December 8, 2014 Share Posted December 8, 2014 1/2 tank Just fill it and go. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 8, 2014 Share Posted December 8, 2014 I was thinking bad gas, so I contacted the PO to see how long it was sitting before I got it. He said it was only 7 months. But I might trydraining it anyway.Since its been sitting so long and it may be a long shot but It can happen...Since its at its half way mark and it starts then sputters... the feeding rubber hose may have split open and since it sits at about the half way mark of the gas tank this maybe your problem... Before you add gas and go you may want to pull the sending just to check it out.... Link to comment Share on other sites More sharing options...
wombat Posted December 8, 2014 Author Share Posted December 8, 2014 Yea, I reckon I will start tracing fuel lines, and and try to pull out sending unit tomorrow. Link to comment Share on other sites More sharing options...
54bobby Posted December 8, 2014 Share Posted December 8, 2014 sounds like it may be spitting fuel through the injector, kind of like sucking air some where. are all your vacuum lines hooked up properly? Link to comment Share on other sites More sharing options...
wombat Posted December 8, 2014 Author Share Posted December 8, 2014 Yea I went over the vaccum lines till I went cross eyed.. I had to step away from it... Link to comment Share on other sites More sharing options...
54bobby Posted December 8, 2014 Share Posted December 8, 2014 make sure the nipples on the tb that the vacuum lines are connected to aren't clogged with grime. try taking some close up pics of under the hood and post them. maybe some one can spot something. Link to comment Share on other sites More sharing options...
Guest Posted December 8, 2014 Share Posted December 8, 2014 I was thinking bad gas, so I contacted the PO to see how long it was sitting before I got it. He said it was only 7 months. But I might try draining it anyway. I would suspect this would be the culprit. If it's ethanol fuel, that stuff will start to separate after only 2-3 months of sitting without being run through the system now and again. Drain that garbage out and replace the fuel filter while you're at it. That little thing could be clogged as well. My truck used to stumble when it first started up when I originally got it, and after replacing the filter, the stumble went away. You'd be surprised what could be lurking in the gas tank.. Link to comment Share on other sites More sharing options...
54bobby Posted December 8, 2014 Share Posted December 8, 2014 maybe top it off with some hi-test and some stay-bil fuel stabilizer. Link to comment Share on other sites More sharing options...
