89JeepMJ Posted November 16, 2014 Share Posted November 16, 2014 will a tranny off a 4 cyl bolt up to 6 cyl or are they completely different? Link to comment Share on other sites More sharing options...
ScottJeep Posted November 16, 2014 Share Posted November 16, 2014 Not that I have the answer...but... are talking Auto or Stick? If stick 4spd or 5spd? Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 16, 2014 Author Share Posted November 16, 2014 not specfic. just in general Link to comment Share on other sites More sharing options...
mnkyboy Posted November 16, 2014 Share Posted November 16, 2014 2.8l V6 yes,4.0l I6 no. Link to comment Share on other sites More sharing options...
Eagle Posted November 16, 2014 Share Posted November 16, 2014 They do not interchange. The 2.5L (I-4) uses the small bell housing bolt pattern from the GM 2.8L The 4.0L uses a larger bell housing, and a larger bolt pattern. There are bell housings to install either an AW4 or an AX-15 on a 2.5L, but they aren't easy to find. Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 19, 2014 Author Share Posted November 19, 2014 Okay thank you Link to comment Share on other sites More sharing options...
Minuit Posted November 20, 2014 Share Posted November 20, 2014 You wouldn't want to bolt a 4-cyl trans up to the 4.0 anyway (if I'm reading the OP correctly). It would destroy it in a heartbeat. Link to comment Share on other sites More sharing options...
