No Heater Blower Fan
  • Replies 51
Is vehicle equipped with a factory radio, and does it work?
Not factory but it works.
Neither the radio nor the cigarette lighter work with or without the 15A radio fuse.
Now I get all mixed up, unless things are real simple.  Does the radio work with the radio fuse in and doesn't work with the radio fuse out or it just doesn't work at all, with or without the fuse?
If the radio just don't work at all, you need to grab that test light and make sure the following fuses are Hot (12vdc):
1. Blower fuse
2. Turn B/U fuse
3. Radio fuse
These fuses are tied back to IP_Splice_E. (mj1988electicmanual pg 8) I can't post photos, yet. Maybe someone can help here. IP_S_E is a five (5) wire splice containing the following:
1. Blower fuse, Turn B/U fuse & Radio fuse.
2. Horn Relay
3. Wiper/Washer circuit
4. Not Used
5. Ign Sw (A)
All three (3) of your symptoms deal with this splice. I can only hope your fuses are Hot.
I found that manual as a pdf and downloaded it.  I don't know what the connector looks like and assume it's under the dash somewhere.  And if those fuses aren't getting power, it appears that the tan wire from the ignition is what feeds that.  So, thinking outloud, I should find that tan wire and test it to see if it's hot on the ignition side of the connector.  If it's not, then do I that the steering column apart?
...tan wire...   BRN (brown) wire from Ign Sw (A).
If your Wiper/Washers work, your good from the Ign Sw (A) to the IP_S_E.
A splice is used when wires of the same circuit come together (No connector). They're tied together, soldered and taped. Look at IP Harness Location in that download you got. Page 91 show location of IP_S_E.
Now I've got a mechanic trying to tell me that it sounds like a power control module. The diagnostic is 112 then the part if used is about 200 and new it's very expensive.  Is there a way for me to rule out the power control module?
If your ignition switch is maladjusted or the connector is fried (common problem) there could be no power to the brown wire that feeds the blower fuse in the RUN position. I suggest you at least visually check this switch and connector first. Here's a good link to check/adjust your ignition switch.
http://www.jeepforum.com/forum/f12/basic-maintenance-ignition-switch-1226376/
Ignition switch alignment procedure:
Ignition switch, p/n J3250576, available at Rockauto and others. Connector also.
Ignition switch alignment:
Fig. 2: Ignition switch rod positioning
On non-tilt columns:
Move the ignition switch slider to the OFF unlocked position (move the slider all the way down, then back two clicks). The remote rod hole in the ignition switch slider should now be centered.
Insert the remote rod in the ignition switch slider hole and install the ignition switch on the steering column. Tighten the attaching screws to 35 inch lbs. (4 Nm).
On tilt columns:
Insert the ignition key in the lock cylinder and turn the cylinder to the OFF unlocked position.
Move the ignition switch downward to eliminate any slack and tighten the attaching screws to 35 inch lbs. (4 Nm).
Install any components removed for switch access.
If you drop the column as described, then you can reach in and unplug the ignition switch and look for fried terminals on the connector. If the connector looks okay, then you probably just need to adjust the rod.
Depending on if your column is tilt or non-tilt and what year truck, the switch might look different than the link, but the procedure is basically the same. The main thing you want to do is eyeball the connector pins.........
