Jaxso32 Posted October 21, 2014 Share Posted October 21, 2014 I'm a few parts away from doing an ax15 swap on my 88, i got a trans and t-case out of a 97 xj. This may be a stupid question because i haven't had a chance to crawl under and look myself, but do i need to modify or get any parts for the newer t-case to work, since the 97 one is so much newer? thanks in advance, also what is the best place to get the pilot bushing for the swap? Link to comment Share on other sites More sharing options...
Incommando Posted October 21, 2014 Share Posted October 21, 2014 My '98 t-case needed nothing when I did my 4x4 conversion Link to comment Share on other sites More sharing options...
87MJTIM Posted October 21, 2014 Share Posted October 21, 2014 To do this swap, I guess you are going from a BA10 to the AX15, you will need the cross member and the t-case shift linkage. The cross member is diff from the BA to AX. Also, (I have been told on this forum) the shift linkage is also diff. I don't know if it is because of the BA/AX change, or a change in the t-case in later years. Rockauto sells the bushings. You should get one for a 74 CJ5 with a 304 V8. There are several write ups on CC about the BA10 to AX15 conversion. Link to comment Share on other sites More sharing options...
xjrev10 Posted October 22, 2014 Share Posted October 22, 2014 Your factory speedo isn't going to work. Link to comment Share on other sites More sharing options...
Jaxso32 Posted October 22, 2014 Author Share Posted October 22, 2014 when i got the transmission and t-case, i got the cross member, shifter, i think the linkage for the t case and slave cylinder as well, all I'm missing is the pilot bushing (probably advanced auto), i just wanted to check to see if i needed anything else to do the swap since its my daily driver i can't have it be out of commission because i forgot a part. I've seen a few of the writeups just want to find the best write up for it. Link to comment Share on other sites More sharing options...
Jaxso32 Posted October 22, 2014 Author Share Posted October 22, 2014 And sorry for asking because I'm guessing its posted on here somewhere, Xjrev10 why will the speedometer not work? Link to comment Share on other sites More sharing options...
shelbyluvv Posted October 22, 2014 Share Posted October 22, 2014 The newer t-cases have sealed output flanges. You will need the yoke of the XJ drive shaft. I have a 97 242 case in my truck and had to have a new rear shaft made to work with it. Old case new case Link to comment Share on other sites More sharing options...
Incommando Posted October 22, 2014 Share Posted October 22, 2014 I swapped a '98 AW4/231 combo into my '91 to convert it to 4wd. In my case the speedo connected and worked just fine but mine is an OBD so...? My '91 rear drive shaft slip yoke also worked fine with the '98 231 but of course I did not try it with a 242. The year and or tranny differences may well change the info but this was correct for mine. Link to comment Share on other sites More sharing options...
xjrev10 Posted October 22, 2014 Share Posted October 22, 2014 You're going from a cable speedo to a electronic speedo. Link to comment Share on other sites More sharing options...
Jaxso32 Posted October 23, 2014 Author Share Posted October 23, 2014 so pretty much i would be better off taking the 3 hours and pull the input shaft from the new one ans swap it into the original so the speedo would work and i wouldnt have to go back and pull a driveshaft yoke Link to comment Share on other sites More sharing options...
Rockfrog Posted October 29, 2014 Share Posted October 29, 2014 Cable drive and electronic speedo drive are compatible. They can be swapped without worry. In fact, 91's used the cable drive unit to run and electronic sensor that threaded onto it, later years used the newer all in one sensor. After 02 things become incompatible (the hall effect VSS came into play) The 97's external slip is the only real issue to worry about. Swapping the main shaft won't work unless you also add the internal needle bearings to the cluster assembly (the later shaft uses an oil film bearing - meaning they simply deleted the needle bearing and resized the main accordingly) and add the complete older tail housing (from main case half back). In 94 the internal gear pitches changed so no new gears will not mesh with older gears. The input gear IS compatible as they never changed that (just have to worry about spline counts). Really, it just simpler to get the newer yoke and bellows and slap it on your driveshaft. Make the case an easy bolt in swap. Shift linkage should bolt right up no issues but due to trans lengths you may need a new adjuster rod, doubtful, I have only ever seen two linkages ... 231, and 242 in an XJ. Changing to the Boostwerks direct linkage will eliminate the issue altogether. Link to comment Share on other sites More sharing options...
Jaxso32 Posted October 29, 2014 Author Share Posted October 29, 2014 i hadnt planned on swapping anything in the case but the input shaft so the original t-case would fit the ax15, i figured that would save me some money and time . I wasnt sure if that would even work thats why i wanted to check here first to see if someone had done it. also thanks Rockfrog for the information Link to comment Share on other sites More sharing options...
