Starter removal???
Your 86 may have the remote (motorcraft style) solenoid on the inner fender, not attached to the starter like most. Regardless, you will still need to remove the wires from the starter and unbolt it from the block. The starter bolts are easier to access on the 2.5 than the 4.0.
PRO TIP: Pull the positive battery cable from the battery before poking around the starter.
