I have a brand new set of 31x10.50R15s off of my old Xj and have a 4.5" lift (SUA) for my Mj. Question is what will the 31's look like with the 4.5" lift. If you try to Google, all you get is Xj pics.
This is an older pic of my truck on low tread 31s with a 4.5 in SUA lift. The rear sat a little high, I have since then lowered it a little using xj shackles and adjusted the front axle with adj control arms.
And even older pic when I had the same wheel and tire combo shelbyluvv posted above
And for suspension reference, this was after I lowered it, and put 265/75/16s which are like 32s on.
