battery change
don't know why pics went sideways. i used # 2 welding cable ang strung it through 3/4 " garden hose where it went along the frame. i changed things up front to get it away from the motor.
They went sideways cause you need to press 'enter' between pictures so they go on different lines.
That looks nice in the bed, especially with the box.
to free up space up front, which allows for better cooling (more area for air to move, plus more air comes in around the headlight socket.
that's sorta a side-effect. but it's mostly to free up space, route wires safely, AND remove front end weight.
It'd prob be a tight fit, but it should be workable. I doubt an Optima is a large as my sub's box. I don't think you're technically supposed to have a battery in a closed cab though, cause I believe (but could be mistaken) they give off some semi-harmful fumes.
As a side note, my Toyota's battery is in the cab, and I haven't had respiratory problems yet from that.
The point of using an optima is they're a gell-cell and don't have any of the nasties of lead-acid batteries. That'd be puking acid and venting hydrogen and acidic fumes or w/e other nasties come out. You don't want to have the battery near you in a roll-over...
Either way, I doubt it would fit.
Since you got the battery out of the way, you're now free to remove some inner fender! Okay, the purists will hate that.
My old Nissan Patrol had the battery under the driver's seat (though technically not "in" the cab, as there was an access panel as a cover. Whenever the voltage regulator took a crap (frequently), I would be bathed in off-gases. Not very pleasant.
the reason i changed the battery and cables is they were all bad, plus, my truck weighs 2200 lbs in front and 1400 lbs in back. next to the battery i'm installing a 32 gal fuel cell, next to that a lock box for whatever. on the battery side of the truck bed, i'm making a quick release holder for my two spare tires. also a brace for the middle of the bed. plus at least two 5 gal gas cans for the motorcycle guys. camping gear. that will bring the rear weight to 2000 to 2100 lbs. approx. maybe even 2200 lbs. i haven't calculated the exact weight yet. i don't like the battery hanging out on the front of the rig. i once found battery acid all over that part of the fender. the goal is as much weight as possible, inboard of the axles. :D
old VW beetles had them under the rear seat.
they frequently dropped through the steel pan and to the pavement because the battery trays would rust out.
LMAO! that HAPPENED to me!
built a dunebuggy with that one after removing the body, replacing the floorpan and shortening the entire pan by 6 inches.
adding to thread: THINGS TO DO
1.rebuild 231 with neutral switch & short shaft kit
2.fix exhaust leak
3.install brake booster, need new lines for master cylinder, line stop, & adjustable porportioning valve. Remove back porportioning valve
4.replace clutch reservior
5.replace stock transmission mount with urethane mount, [adapt mine and or replace]
6.check control arm for type of bushing, and or replace. Add bracing to arms
7.have driveshaft shop lengthen front driveshaft
8.make steering box brace
9.replace radiator with 92 or newer radiator & catch can
10.replace doors if possible
11.buy 32 gal gas tank and install with fuel pump and lines where needed
12.remove charcol canister & lines & plug done
13.build spare tire mount
14.weld spot welds with stitch welds on frame & suspension
15.replace springs
16.mount new shocks
17.make brackets for front shock mounts
18.make fender stiffener from shock mount to shock mount across motor
19.six wheels and tires done
20.brakes done
21.axles r&r done
22.mount gauges & pod including wiring them
23.mount inverter & wire it
24.move battery done
25.mount passenger seat
26.mount corbeau seat belts
27.make bar for seat belts
28.make bar for passenger feet
29.make bar for passenger hands
30.finish interior
31.mount new hood
32.mount air cleaner with hose for outside air
33.mount spot lights with relay and wiring
34.make brace to stiffen bed sides above spare tires
35.make or buy then mount tool box
36.move rear bumper closer to frame
37.make mount for hi-lift jack
38.mount spare tie rod
39.fix speedo
40.mount accusump,lines, whatever foa is $ 165.00
41.make front bumper out of one inch tubing
42.fix back slider window- drill holes to mount some kind of latch
43.mount amber light
44.pull transmission & check rear main seal,flywheel, pressure plate, throwout bearing, pilot bearing
45.put spares in tool box
46.map senser
47.coil
48.resister
49.belt
50. make skid plates for gas tank, transmission, engine, and front of engine out of alum
51. install wink mirror done 52. replace windshield done the list to finish before baja or reno,las vegas
