88Mj14 Posted August 12, 2014 Share Posted August 12, 2014 okay so I'm doing the famous 97+ swap.. and the little less famous full interior swap. here's my problem. If i choose to use the center console from the 97 that means I'm going to have to relocate the ebrake setup. i understand i could still keep it in its orignial spot but id like to keep the center console emergency cable functional for more of an authentic feel. now. How would i go about doing this; would i need the orginal cable from my mj, or the cable off the cherokee? either way ill have to buy one new so your guys help would be greatly appreciated as to which one to buy and where. thank you - paul Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 12, 2014 Share Posted August 12, 2014 If your front cable has not been replaced it will need to be as it won't be worth working with. You'll likely want new rears also and the only place I have found them is rockauto, the Raybestos is good. You'll need to mount the handbrake and then measure for a new front cable. If you cannot find one you can make one or have one made. Link to comment Share on other sites More sharing options...
danbyrambler Posted August 13, 2014 Share Posted August 13, 2014 You'll like it here on CC - - Tons of info/help/expertise - - Search is a good tool - 97+ Console & P Brake here, NAXJA, Pirate & others This is prob all you need: http://comancheclub.com/topic/41570-xj-parking-brake-in-a-mj/ Link to comment Share on other sites More sharing options...
VolsJK Posted August 13, 2014 Share Posted August 13, 2014 Hard line cable is CHEAP CHEAP. I'll be doing this soon and will do a writeup. Alexia did this, maybe he could share some insight. Link to comment Share on other sites More sharing options...
Alexia Posted August 13, 2014 Share Posted August 13, 2014 Hard line cable is CHEAP CHEAP. I'll be doing this soon and will do a writeup. Alexia did this, maybe he could share some insight. Here is what I did similar to everywhere else. http://comancheclub.com/topic/32740-alexias-1987-to-1997-comanche/page-4?do=findComment&comment=352849 I just looped the existing MJ parking brake cable under the carpet behind the seat. Link to comment Share on other sites More sharing options...
