Stalling Out
OK I have a 87, inline 6, 5 on the floor.  I searched and couldn't find a answer and hope that someone can help me out as this has me stumped.  When I go to engage my clutch (push the pedal to the floor) the Comanche dies.  It will just spudder and die out.  I cleaned my idle air control valve out with some throttle body cleaner and I put new plugs in.  The wires looked good but I can change them if need be.  Any thing else that I can try or do to figure out the problem?  I do not think I have a vacuum leak but I could have looked passed something very easily and not known it.
Check under the dash for any interference between the clutch pedal arm and any wiring. Clutch actuation is entirely hydraulic and there should be no vacuum or electrical connection. An electrical short or a wire connection that is being mashed or partially disconnected are the only things I can think of.
Pushing the clutch peddle to the floor doesn't engage the clutch, it DISengages it. You're saying the truck runs with the clutch engaged, and stalls when it's DISengaged?
Even if your slave does need to be "bleeded", that is not your problem.
As mentioned above the clutch is a self-contained hydraulic system....it is not connected electrically or by any other way to the motor that would cause it to stall (normally)
You should take the advice given above and with a helper just observe you clutch pedal operation....is it interfering with anything else as it goes through a normal cycle?
It was connected to the vacuum canister that was mounted to the original bumper.  I needed to relocate it and threw it in the engine bay to get it out of the way and the old line snapped.  I doubt you will have a line that is this bad, it could just be a small hole as well so I'd just make sure to check all the lines.
I ended up getting the smallest line they had at AutoZone and just putting the two ends in the new line due to the new line being just a little too large.
It did help my problem just it did not fix it completely.  Another Idea is to check the fuel filter I know sometimes that can cause problems and it just a good thing to replace if it hasn't been replaced lately.
I'd also take advice from eagle and yxmj they know much more then me.
  • 4 weeks later...
Ok back to this problem how. I had to replace the head as the bottom bolt of the thermostat bossing broke off. Got everything button back up and running and still got this problem. I did check for any issues that the pedal could be causing and it is all clear nothing in the way. The truck will idle without stalling out. If this problem can be figured out I will have a good running truck.
Well Cruiser you help me out and didn't even know it.  Well I think I figured it out.  I found where you responded to someone else thread where they were having the same problem where if they stop they would also stall out and die.  You told them to check the throttle butterfly and idle it up.  Well I was idling at around 500ish.  I had helped and turned it up and now it doesn't stall out.  I turned it up to about 1000ish.  Runs like a charm.
Which screw did you turn?
I follow this post, but it was the screw on back throttle body. I can get a picture tomorrow but it's the screw that when you rev the motor by hand it sticks out just a little bit and has a hole on the other side to stick the Allen rench threw.
I flet the need to write the following just because some guys fought high idle issues because of "Uncle Bob".
Cruiser’s Renix Throttle Body Butterfly Adjustment
Okay. Let's start from scratch. First off, that's not an idle adjustment screw. It's a throttle butterfly stop screw. It's purpose is to allow the butterfly to be as close to completely closed as it can be without binding or wearing into the throttle body. It was never intended to be adjusted in the field. But, Uncle bob didn’t know that, did he?
Engine off. Back off the butterfly stop screw with a 3/32" allen wrench until the butterfly is completely closed. Now. turn the screw in until the FAINTEST movement of the butterfly opening is detected. This can be done more easily with the throttle body removed. If you remove the throttle body, be sure to replace the gasket underneath it after thoroughly cleaning the old one off.
Revised 07/07/2012
Been doing some more research and don't know if it could be the problem or not but some people say that the CPS or TPS can cause my stalling that I am experiencing.  So after work tomorrow I will be checking them out.
Ok so i check the tps and that is good. When I check the cps it only showed .2, so I'm guessing that it is bad? I never have a problem with it starting after it stalls out but I have read that the cps can stall out the truck. Also isd there a easy way to get the cps out? I just want this problem solved. Hate to do it but I might have to drop it off at the shop if I can't get it to run right.
