Donny88 Posted July 7, 2014 Posted July 7, 2014 New bled master cylinder, brake lines bled and new pads and shoes. A little bit of pedal untill I start it and it goes to the floor .does not stop like it should. Any ideas?
onlyinajeep726 Posted July 8, 2014 Posted July 8, 2014 Booster bad? When you press the pedal, is there a slight rise in engine RPM accompanied by any air leak sound? That was my problem and I swapped in the '95/'96 XJ dual diaphragm booster and MC.
Pete M Posted July 8, 2014 Posted July 8, 2014 yup, I had the same puzzling issue and swapping in a booster solved it. :thumbsup:
