Best Products For Worn Out Suspension
I will be going thru and replacing all the worn out suspension parts on my truck this next week and looking for opinions on the best kits/manufacturers for the bushings, shocks, etc.Will be using it mostly on pavement with some towing and occasional off road in the form of fields and mostly looking for smoother ride and longest lasting. Currently have 235/75 R15's on factory rims with the stock setup.
While looking thru the forums have seen a couple that discussed using airbags. With a stock setup, would there be any difference in the ride if i installed airbags as helpers, especially in the rear and does anyone know of a kit, preferably bolt in as my welding skills don't exist yet.
JKS makes the best track bar for stock hight mj and xj jeeps. I have tried several and their's doesn't induce bump steer.
what is bump steer as i think i might have it??
http://www.quadratec.com/jeep_knowledgebase/article-68.htm
"If you have ever driven a lifted Jeep one thing you notice is the steering.  If special care is not taken in the design the vehicle will dodge and dart whenever a bump or hole in the road is hit.  This is because the drag link is either being pushed or pulled by the vertical suspension movement due to not being parallel with the trac-bar.  This is commonly referred to as Bump Steer......"
what my stock height is doing is in low speed turning the steering wheel feels like it is moving (rocking) from left to right and back repetitively.
Track bar.
Track bar.
the track bar is less than a year old with no off roading on it. can it already be bad??
