Slight Wobble After Lift
Those don't look like blocks... just the spring perches.  Though they do look a little thick from the picture.  Pictures add 10 lbs, right? :yes:
But as advised, fix the angle of your rear diff for starters.  The front looks off too, as mentioned.  Also, something I didn't see mentioned was your harsh steering geometry.  With the stock inverted y-steering and 4.5"+ of lift, those angles are considerably more stressful on everything.  If you wish to keep the stock steering, I'd advice a drop pit man arm as a must.
Those are not regulation D44 perches mate. It looks like whomever welded them on the axle tubes screwed up causing the axle pinion to point up towards the t-case, thus ruining the pinion angle.
You would need probably a 20*-25* shim to rotate the axle back down to. Nobody makes those AFAIK - 8* is about max. Shims are only used for fine adjustment. I think the best way is to cut them off and re-weld new perches.
Time to cut off the perches and start over... On the plus side new perches are cheap if you need them
if it's a wobble (rather than a vibration), it's likely your alignment.  I would get that fixed first before attacking the rear.  as to the rear angles, you might be able to get away with just new joints an the 6* wedges.  it's not ideal, but might be close enough.  but as I said, get the front aligned first or else it might interfere with the diagnosis.
"Slight" is a subjective word. With the rear drive shaft geometry as posted in your pics, wobble and/or vibration has to be a bit more than slight. But post up the alignment results if it helped any.
