C101 Issues
Meant to ask you Cruiser... is there any potential MPG gains by doing the elimination and ground update?
Yes. Just the fact that the system can operate optimally, as designed is good. My observation on the O2 sensor is a good example of before and after.
I've been meaning to do this on my '88 as well. What I really don't like about it is that you're left with that giant loop of wire loom:
Image Not Found
Personally, I think there's already too much loom that traces all over the place. It's just ugly. Anything special to look for if removing the C101 and cutting the wires way short so it doesn't have the loop?
Shorter is just fine. I allowed my 22 year old neighbor do the one in the photo. Kept it simple and him involved.
  • 4 weeks later...
Go pin for pin. Sometimes colors change at the connectors.
I just did my truck this weekend and there are definitely a few that change colors so do as Cruiser says and go pin to pin. I also had 4 wires that didn't go anywhere on the other side of the connector so don't let that confuse you. And just to let everyone know I didnt have any problems with my truck before eliminating the c101 but it does feel like it runs more smoothly now.
Typical.
Always pin to pin when eliminating a harness connector to maintain continuity. Wire color has nothing to do with it.
When splicing a connector into a harness, then maintain wire color to wire color through the connector.
Typical.
What did you guys do with the spare wires? Just leave them be?
Edit: seems like the wires match to the wires of the auto transmission plug wires...
thanks to cruzers prodding me I did the c101 elimination, but, I  kept the c101 housing for Original look. Posted a DIY. It made a world of difference. Sensors need close to 0 ohms of resistance to work correctly and the c101 absolutely adds unwanted resistance. If eagle is lucky enough to have zero resistance on his c101 now I have to bet he'll get some eventually. The fact that they eliminated it in the factory should be more than enough evidence that its the right thing to do. I'd be interested in eagle checking resistance on each connector pair and letting everyone know the numbers.
I Say. Before you so anything else make sure you are getting less than 1 ohms resistance on sensor ground and eliminate the c101. your mother will be proud.
