Anyone have a source for a 52068061-39 tooth speedo gear?
Green-Long Shaft
Morris has N/A for long shaft 38, 39 & 40 tooth  :fs1:
Currently have an old Garmin stuck to the dash, it's getting old.
It would depend more on your original tire size, although probably we can get that from your gear ratio/tranny combo.
I personally didn't notice any appreciable difference in my speedometer's inaccuracy when I switched from the 225/75R15's that were on mine (as per the tire info sticker) to 235/75's, but then that's not much difference in diameter... about a half inch. Works out to about a 2% increase in circumference and therefore wheel speed (You'll be doing 61.2 when your speedo reads 60) but in all honesty that's within typical calibration error in a new car, so meh.
I may be wrong on this, but I believe the smallest tire that was fitted to the Comanche was the 205/75/15. Going to a 235/75 from that size would be about a 10% increase in wheel speed, which starts to become significant. You'll be going 66 when your speedo says 60.
However, these are based on nominal tire sizes. Actual tire dimensions will change depending on the construction of the tire, pressure, load, wear, etc., so YMMV. If you really want to know how inaccurate your speedometer will be, you'll pretty well need to change the tires and then find some better calibrated way to measure your speed, like a GPS or radar unit.
