I was cruising along under prime conditions... then engine started missing, sputtering, no acceleration.
I pulled over. Idle was rough. I shut her off.
I cranked her up. idle revved as usual, rough but better. I tried to pull off and sputtered up to 35mph.
I just replaced CTS, IAC, air filter, plugs & wires, cap & rotor, cleaned TB, new injectors, and cleaned all ground points / connections on the harness as recommended.
Been runnung fine, ran great to and from church this am. Tracked down a ground-based lighting problem (wrong bulb in socket from previous owner). ran great leaving town then WHAM. She tanked. Will crank and run but poorly.
Any ideas?
I've never had a fuel filter go like that all of the sudden from great to foul, but it's my only thought. It was my next task (ain't had her but a month now... I have a list)
thanks,
Rev. Toid
Checked the oil? Mine started running poorly once it got between the add mark and the end of the stick....
Have you checked the fuel pressure? Its possible the pump is going out.
Last guy said he just did a new tank n pump job. And I checked the oil. S'good. I just changed it yesterday
Bad CPS would cause stalling and intermittent starting.  Ignition coil heat soak possibly?
Mine acted up like this when fuel pump started going out.  I know you just said that it was replaced by the PO supposedly, but it could've suck some junk from the bottom of the tank.
What engine and tranny do you have?  I'm assuming it's a '90 via your signature.
Somewhere in my last move I lost FP gauge... will get new one tomorrow n check it.
I forgot to mention a fuel odor near back of truck briefly yesterday. I dismissed it because it did not recur.
If regulator is bad pressure will be too low or too high?
1990 4.0 auto. Po replaced tank with pump supposedly. Said it was expensive and aggravating. The reason he decided to sell it.
In retrospect, I do not believe I mentioned the backfiring that occurred alongside the sputtering when throttle was applied.
I found the ballast cracked in half this am. Could be the issue... huh?
The FP ballast I keep reading about is in the driver fender well up near the air box, right?
I changed the fuel filter and bypassed Ballast. I could hear the pump running when I turn the key but I could not check to see what the pressure was I could not get a fuel pressure gauge today maybe I will be by the parts store tomorrow to rent it since I couldn't find one to buy.
I did manage to get it to crank after a lot of pedal coaxing. Butit dies as soon as you give it throttle.
I disconnected the TPS and it died but I don't know what that tells me I may have to tow it to the mechanic if my fuel pressure doesn't tell me anything
Either way its a replacement for the pump... I'm assuming. I got a Precision brand pump available at Oreily's. Only 70 bucks. But I hate to keep throwing money... what about the regulator? What are the symptoms of it going out?
Its a hard start but it idles pretty well if I can get it started by flooring the throttle. But one touch of the throttle is all it takes to kill it.
This makes me regret being stupid.
Its a hard start but it idles pretty well if I floor the throttle. But one touch of the throttle is all it takes to kill it.
Ain't the regulator. Fuel volume and pressure are probably the issue. Carter or Bosch pumps are the best. This can be tested.
Just stopped at oreilys n rented a gauge. If its not too much bother... beyond merely testing pressure on the rail what am I looking for?
Key on engine off pressure and key on engine cranking, & if I can get it cranked... with engine running..?
Hate to be a burden...
Well, Reverend, since we're called to carry each other's burdens, here's what you're looking for. 31 PSI at idle and 39 PSI with the vacuum line removed from the fuel pressure regulator.
Thank you. I was thinking there may have been more to it than that. On my old Super coupe it was 3 different pressures to be measured.
S'good to have fellows with genuine concern toward helping folks... I'm generally proficient with OBDII BUT I haven't figured out this jeep setup yet.
I just hope I can get it to crank son I can check it at idle. What should it read when the pump pressurizes before cranking?
OK. I turn key on, I can hear the pump. No pressure on the gauge.
I turn engine over but will not crank and no pressure on the gauge. Needle doesn't even move.
The bad thing is I just filled her up so tank is better than 3/4 full.
  • 1 month later...
